Raven Luni
- Oct 15, 2011
- 798
- Joined
- Oct 15, 2011
- Messages
- 798
Greetings,
Needing something to program my PICs with I had the idea of ripping the guts out of an old keyboard and using the LEDs as the serial output (writing a program to make them dance for a bunch of data is easy).
Here is my initial design:
According to the specs an ATX supply should do nicely since it has 5V and 12V lines and the minimum spec for high voltage programming is VDD + 3.5 - a far cry from the 13V people seem to think is crucial.
LED outputs are assigned as follows:
Num Lock: Clock
Caps Lock: Data
Scroll Lock: Verify (off = load)
The CAPS button on the right isnt really a button - its just the column and row points for the caps lock key. This means that the PIC can set the caps lock status when verifying and the loader program can read it.
I've made a few assumptions with regards to things like the LED connections. I'll have a better idea once I have a proper look at an old keyboard. Polarities might be different, transistors might need to be PNP etc. but hopefully theres enough to go on for now and generate some feedback.
So - what you think?
Num Lock: Clock
Caps Lock: Data
