PICBASIC serial communications problem
Hi all
I am trying to communicate with a computer using pic18f4620 in basic
programming. I am using the hyperterminal to send and recieve
messages. I am displaying the incoming message onto an LCD screen. When
I run the code below the LCD screen displays garbage. I am not sure at
what baud rate this program should be working either. Please help.
Include "modedefs.bas"
' RS232C Serin2 and Serout2 Demo Program
' Define ONINT_USED to allow use of the boot loader.
' This will not affect normal program operation.
'Define ONINT_USED 1
'DEFINE OSC 32
DEFINE LCD_DREG PORTD 'LCD data port
DEFINE LCD_DBIT 0 'LCD data starting bit (0 or 4)
DEFINE LCD_RSREG PORTB 'Register select port
DEFINE LCD_RSBIT 7 'Register select bit
DEFINE LCD_EREG PORTB 'LCD enable port
DEFINE LCD_EBIT 6 'LCD enable bit
DEFINE LCD_BITS 8 'Defines the number of bits wide
DEFINE LCD_LINES 2 'Sets the number of LCD lines
DEFINE LCD_COMMANDUS 2000 'Sets the LCD command delay time in
us
DEFINE LCD_DATAUS 50 'Sets the LCD data delay in us
'ADCON1 = %00001111
' OSCTUNE = $40
' OSCCON = $72
DEFINE HSER_RCSTA 90H
DEFINE HSER_TXSTA 20H
DEFINE HSER_BAUD 9600
' DEFINE HSER_SPBRG 25
TRISB = %00011111
PORTB = %00000000
TRISE.0 = 0 'Set PORTE.0 to output
TRISE.1 = 0 'Set PORTE.1 to output
TRISE.2 = 0
TRISD = 0
TRISC = %10010000 ' Bits 7 & 4 set as Inputs
PORTC = %00000000 ' All off to start
PAUSE 1000
bootupscreen:
LCDOUT $fe,1 'Clear LCD screen
pause 500
LCDOUT "USART TESTING" 'Put up self test display
pause 500
' LCDOUT $fe,1 'Clear LCD screen
LCDOUT $fe, $C0 'Start of second line
LCDOUT "THIS LINE IS CRAP"
pause 500
' ADCON1 = 7 ' Set PORTA and PORTE to digital
' Low PORTE.2 ' LCD R/W line low (W)
' Pause 200 ' Wait for LCD to start up
'Vars: Tx var PORTC.6
' Rx Var PORTC.7
' rec var byte[1]
' 'rec var BYTE
'loop: HSERIN [RX, STR rec\1]
'loop: serin2 rx, 84, [STR rec\1] 'input
' IF REC = 1 THEN GOTO loop ENDIF
'outlcd: lcdout $fe, $94, "RECEIVE = ", STR rec\1
'HSEROUT ["RECEIVED"]
' serout2 Tx, 84, ["RECEIVED = ", STR rec\1] 'output
' PAUSE 500
Rx Var PORTC.7
rec var byte[1]
send VAR BYTE
send="y"
' HSERIN {ParityLabel,}{Timeout,Label,}[Item{,...}]
' HSERIN2 {ParityLabel,}{Timeout,Label,}[Item{,...}]
' SERIN Pin,Mode,{Timeout,Label,}{[Qual...],}{Item...}
' SERIN2 DataPin{\FlowPin},Mode,{ParityLabel,}{Timeout,Label,}[Item...]
' Hserin 10000, start, [char]
' serin rx, T9600, [STR rec\1]
outlcd: lcdout $fe, 1, "RECEIVE = ", STR rec\1
serout2 Tx, 84, [send]
' SEROUT Tx, T9600, ["RECEIVED"]
goto loop
