Pioneer Tuner F-Z93L troubleshooting
Hi everybody
I have a pretty old Pioneer Tuner F-Z93L part of an entire stereo
device S111. The problem with the tuner is that it keeps searching on
the entire FM-band in order to find a station. It never stops.
I think it has something to do with the treshold level to distinguish
noise / signal.
In it, I descovered a PCB with number ANPI356-B. There's another PCB
near the front, carrying the LCD and some other stuff.
Has anyone advice upon this, similar problems in another tuner, a
schematic diagram would be perfect :)
Thanks for help
Eng. GDB
Mark D. Zacharias
Hi everybody
noise / signal.
Thanks for help
Eng. GDB
If you can manually tune a station, and it's just that the scan-stop doesn't
work, the discriminator needs adjustment. This is actually quite common on
digital tuners. This normally requires a service manual to locate the test
point and the adjustment coil(transformer, actually), and a voltmeter (or
the 'scope on a small DC range) to adjust for minimum DC at the test point,
when tuned to a station near 98mHz.
Also, the VCO may need adjustment if the stereo beacon lamp or LED does not
come on reliably.
Mark Z.
Colin McCormick
Hello
I've got a F-Z92L tuner, which may be compatible
with your system (connected via a short ribbon
cable and connector). Yours for the price of UK
postage or collect from Devon. Being quite
light I would expect it to cost £7.20 to post.
Contact me directly on [email protected] if
this is of use to you.
Regards,
Colin
Similar threads
Replies
17
5K
jakdedert
Replies
3K
Mark D. Zacharias
Replies
2K
Sascha Schmitt
