PlayStation 2 half dead
Mike
I have a playstation 2, and it will power up just fine. green light. there
is no action from the drive at all. The eject button is unresponsive, the
tray will not eject or load, the disc motor will not spin, the laser is
unresponsive, and there is no servo activity from the laser. no focus
movement, no nothing.
its like killing the power to the drive. The system WILL power up, but the
drive is totally dead. Any ideas?
Mike
playstation 2 dude.
playstation 2 dude.
playstation 2 dude.
Mike
found out. BA5815M is defective. it looks like by the design, a servo
controller IC. I jumped the fuse, and a roll of smoke came out of it.
i believe the tray being stuck put too much stress on teh chip thus
destroying it and blowing the fuse.
anyway, before the chip smoked, the door moved a quick milimeter before
detonation. lol.
i need a new IC.
Chris Oates
Mike said:
playstation 2 dude.
you cannot begin to imagine how amusing
it is to be a 55 year Englishman and be
addressed as 'dude'
LASERandDVDfan
Serves you right. You should have installed a replacement fuse of the type
required instead of jumpering it.
Nope. All that would happen is that the drive would attempt to open the
drawer, but the SYSCON would time out and reload the drive.
It's more a strain on the drive motor than it is on "teh chip."
As for destroying the chip: the fuse blew in the presence of an internal
circuit error, protecting the chip. *YOU* destroyed it when you decided to
bypass a protection fuse like a stupid know-nothing idiot!
Furthermore, it's also possible that the chip could have blown due to your
soldering because it's certainly likely that you may have unknowingly
cross-soldered something, causing a short circuit that may have zapped the IC
in question, and may have taken other parts in the same circuit along with it!
detonation. lol.
i need a new IC.
No, you need a new PS-2, and the self-restraint from trying to fix it when
something goes wrong with it.
If you can manage to install the new chip in your busted PS-2 without
destroying it with the soldering iron or ESD, you'll only blow it out again
when you fire it up (assuming the jumper you installed in place of the fuse is
still intact). There is something else wrong with the affected circuit that
has caused the fuse to blow, and that has to be addressed first.
But, getting the parts to fix it is not going to be cheap, and that's assuming
that they're available to begin with!
Furthermore, you need good technical proficiency, as well as the proper tools,
to service these things correctly, a trait that you apparently lack as
evidenced by the fact that you needlessly destroyed a non-standard component
and possibly caused a cascade of other failures within the same circuit with
that bypass stunt you pulled.
The cost for repair of this deck will definitely exceed its value in the
condition you put it in, so you may as well shit-can the motherfucker and buy a
replacement.
The reason why I'm bitter, because I had to clean up after someone else's
attempted repair of their PS-2. They didn't fix the problem (disc read error),
but they did succeed in damaging their console even more.
So, you can understand where I'm coming from, as well as other techs who had to
clean up after someone else's escapades of tweaking potentiometers, sticking
screwdrivers in places while the unit is still energized, or perhaps even
forgetting to supply all the parts they had taken out when they send whatever
they have to the repair shop. >:-[ - Reinhart
Mike
dude, the IC failed causing the fuse to blow.
Its a COMMON PROBLEM. I found this out before you posted last night, i found
several websites relating to the issue. its a common failure part. the
thermal pad has a tendency to lift from the heatsink. thats why. the chip
gets damaged internally, thus popping the fuse. that fuse ONLY supplies that
chip, and no, im carefull when i solder.
i found the same IC in a 48x cdrom, and replaced it. It works fine, thank
you very much. now STFU.
detonation. lol.
i need a new IC.
replacement.
James Sweet
Did you replace the fuse while you're at it? The value is probably not
critical, but it would be a good idea to have one.
Mike
yes i did. i put a half amp, 32vdc fuse. its a little white one.
James Sweet
Cool, always nice to hear of a successful repair.
LASERandDVDfan
Well, why didn't you mention the details in the first place?
In this case, I withdraw my claims and apologize to you then. - Reinhart
