Playstation 2 help sodering help
H
Hallhair
i have a playstation 2 and i put a mod chip in it and i have 5 more
wires to wire but i don't know how to wire them becsaue the soder
won't stick to the board how do i make it stick the diagram of my
soder points is at http://www.modchip.ca/install/ps2/chipmod/chipmodimages/chipmod10.jpg
and the wires i need help with are G I B F H and it is on the back of
the playstation and the holes are really small and i can't get even
the wired through so if there is anyone who can help it would be
great.
Johny Looser
great.
This is probably to late, but you need to remove the epoxy coating
from the pads. The epoxy is the varnishy finish over everything.
Gently scrape the coating off with a dental pick, or even a pocket
knife. Your solder will then be able to stick to the pads.
As for holes? What holes, my PS2 was all surface mount stuff. There
were no holes. Don't start soldering untill you have all the tools,
(SMALL soldering iron, and 30 AWG kynar wire). There are too many
people who were in a rush and ended up with a paperweight.
I got mine working the first time. I took my time though!
-Good Luck
