PLL input filter vs. loop filter
Tom Becker
Folks, I've been working with a 4046-based shaft rotation tracking PLL
circuit. The source is a weak, noisy and pretty sloppy
inductively-generated shaft speed signal. I want to regenerate and
track it's principal signal of 252Hz, but that is punctuated with
occasional large and sometimes periodic low-frequency resonances and
gear noise.
The physical device is subjected to random accelerations from any
direction so while tracking it must remain responsive to pretty rapid
input phase and frequency changes - yet be able to flywheel though the
missing cycles caused by the resonances.
That seemed a challenge, but I have found reasonable success with simple
passive filters for some input conditioning, and for the loop filter.
While experimenting with active filters, though, I've found that any
low-pass on the input reduces responsiveness, thus tracking. As I write
this, I think I see that's due to any integrator eating time.
That suggests that whatever low-pass filtering I need should be done in
the PLL loop, not ahead of it. That leaves me with the low-frequency
resonance effect inside the loop, though, and that can ding the VCO
pretty well - producing a cycle-slip or breaking lock.
I'm tempted to try a twin-T notch or a high-pass to remove the low-F
stuff ahead of the loop, but I know I'm still playing with time. In
general - intending to optimize for tracking - should I try to clean up
the signal ahead of the PLL or be more selective in the loop filter?
Or am I off track? TIA.
Tom
John Larkin
gear noise.
Tom
What's the actual signal frequency range? 252 Hz +- what?
If it's narrow, a bandpass filter is appropriate. Its bandwidth should
be narrow to kill noise but wide enough to allow it to track changes
in the signal frequency. It's possible that all you need is a good
bpf, no pll at all.
A 4046 requires a logic-level input to any of its phase detectors, so
I assume you have a comparator in the front-end somewhere. If so, that
will make trouble at low s/n. A linear phase detector (a multiplier or
a synchronous rectifier) is better at pulling a weak signal out of
noise.
John
Tom Becker
... 252 Hz +- what?
I'm expecting +/20% instantaneous error.
... a good bpf, no pll at all.
Maybe a tracking BPF, yes.
... A linear phase detector [] is better at pulling a weak signal out of noise.
I'm using PC1 of the 74HC4046, the XOR comparator. I had no fortune
with either of the edge detected phase comparators. Although I am using
an opamp as a comparator at the moment, it has offered no advantage over
the biased inputs of the modern IC, which permit 20mVPP AC-coupled inputs.
A tracking BPF. Hmmm. Thanks.
Tom
Tim Wescott
Tom said:
... 252 Hz +- what?
of noise.
Even the XOR still needs a logic input, which tends to magnify noise
when the SNR is low. John's suggestion of replacing the XOR with a
multiplier is not to be ignored, but a tracking BPF may be the better
thing to try first.
Tim Wescott
Wescott Design Services
http://www.wescottdesign.com
Posting from Google? See http://cfaj.freeshell.org/google/
Joerg
Hello Tom,
The frequency is kind of low for this but it might be worth checking it
out: The old technique of Q-multipliers. Basically these are resonant
circuits where the connected stage is adjusted in feedback so that it
just doesn't oscillate. The closeness to the point of oscillation
determines the bandwidth, the closer the narrower.
This doesn't need to be LC, maybe a gyrator filter? Anyway, it'll take
some serious studying and simulating to make sure it is stable and has
the behavior you are after.
If by +/-20% you mean the deviation in rpm you'd have to start it pretty
much wide open and then have it narrow down. It almost sounds like a job
for a uC or low-end DSP.
A PLL could work as well. But I'd consider something better than the 4046.
Regards, Joerg
K
Ken Smith
noise.
http://www.fairchildsemi.com/ds/MM/MM74HC4046.pdf
Check out the self biasing circuit on pin 14. You only need provide a
coupling capacitor and the 4046 will work with a sine wave input.
K
Ken Smith
thing to try first.
Also:
If you are making in multiplying PLL and have a lowpass before the
comparitor, you can feed a small sawtooth, made from the VCO, into the
comparitor to cause it to PWM. This allows you to multiply moderately
well without a true multiplier.
Ben Jackson
You can't track "instantaneous" error. In the PLL, the bandwidth of
the low-pass filter on the output of the phase detector determines
the agility of the PLL. Tracking "instantaneous" error would be
equivalent to not having a PLL at all (in your 1:1 case). In your
Once you quantify "pretty rapid", then you know the bandwidth of the
loop filter when you have an input signal. Then "flywheeling" would
be equivalent to switching in a low-bandwidth loop filter when the
input signal is invalid. The problem, then, is detecting when it's
invalid.
What about this:
signal --> phase detector --> high-bw lowpass just to convert
phase detector pulses to voltage --> clamp to a voltage equivalent
to 252 +/-20% at the VCO --> lowpass filter to "pretty rapid"
rate --> vco --> back to phase detector
So now if you miss a pulse, the clamp after the first filter stage will
clamp that to 252-20% and the whole PLL will start slewing toward that
rate at the "pretty rapid" rate. If you continue to miss input signals,
eventually "no input" will become 252-20% steady state.
If you expect to lose signal long enough that the "pretty rapid" rate
will see an unacceptable change, you could take the output of the first
filter stage, detect V < 252-20% with a comparator and use that to
dramatically reduce the bandwidth of the second filter stage (or switch
in a circuit that can quickly sample and hold the current VCO input
voltage).
For a super slow speed like this, the idea of using a micro that someone
else had is probably even better...
The problem with a filter in front of the PLL is that you can't "remove"
missing pulses. A low-pass filter would work fine if you were seeing
extra pulses...
Joerg
Hello Ben,
True. 250Hz is easy to do. The MSP430F2013 contains a 16bit engine and a
16bit SAR converter. Seems almost ideal for this app. When there are too
many unknowns in the signal characteristic a uC allows easy adaptation
of algorithms, including a lot of stuff that simply cannot be done in
the analog domain with any reasonable effort. That was hard to say for
me as an analog guy but 'tis how it is.
If the F2013 aint't enough there is the F4xx family. These come with
more RAM and hardware multipliers. Like the Camaro of the MSP430 series.
extra pulses...
With a uC you probably could.
Regards, Joerg
Tom Becker
... feed a small sawtooth, made from the VCO, into the comparitor to
cause it to [] multiply moderately well without a true multiplier...
Very interesting, if I understand. Can you find a link to an example?
Tom
Tom Becker
Yes; my poor descriptor should have been "maximum brief" error, probably.
The problem with a filter in front of the PLL is that you can't "remove" missing pulses.
No, but I believe the "missing pulse" - actually a missing
zero-crossing, I think - is just an artifact of the summation of several
signals. Envision 252Hz riding on an 18Hz narrow Gaussian pulse and
you're close. I often see 13 pretty clean cycles of 252Hz, then a flat,
then 13..., instead of 252/18=14.
Can't I just notch the 18Hz? Can it be done in the loop filter?
Tom
John Larkin
... 252 Hz +- what?
Tom
How about using a switched-capacitor bandpass filter? Design one
filter section to give a 90 deg phase shift at filter cf (that stage
would actually be a peaked lowpass, technically). Hang a phase
detector across that stage's input and output, lowpass filter, and
servo a v/f as the clock of the filter. That could be a tracking bpf
with just a few ic's.
John
Jim Thompson
invalid.
What about this:
voltage).
extra pulses...
The way to do it: NARROW PLL restores the carrier, then multiply
noisy signal with restored carrier. It's called correlation ;-)
...Jim Thompson
Tom Becker
Did it. At one point I had a /8 in the loop; I clocked an eight-cap
Tayloe filter with the VCO. Spectacular selectivity and fun to
implement; it's like a _visual_ filter on a scope.
I had a lot of trouble with the loop, though; essentially nothing got
through the Tayloe if it was unlocked - so it was hard to lock and hard
to keep locked. It just wasn't very stable trying to follow a
mechanical clock source; too sharp, probably.
The tracking BPF started me thinking about it again, though. I've
learned much since then so maybe I'll visit this again.
Tom
John Larkin
Is that one of those Resistor/rotary switch/buncha caps things? Those
are so cool. But I was thinking about a commercial IC switch-cap
bandpass, an MF10 sort of thing, or one of the more modern versions.
Maybe most of the selectivity could be downstream of where the phase
detection is done. That almost defies logic, a narrowband tracking
filter with fast, wideband tracking ability. That wouldn't be real bad
as long as the noise was fairly incoherent.
Next step, FFT?
John
Tom Becker
Next step, FFT?
I guess that's not out of the question. At Joerg's suggestion I took a
look at the MSP430F2013. Unbelievable for $1.50. I'm hesitant to pick
up another platform - I'm an old 8008 guy who's settled on AVRs for now
- but fast 16-bit mixed-signal processing is very inviting. [It's got a
PGA on the ADC input, too. I dream of a processor that offers an
on-the-fly programmable analog signal processing section; this is
getting close.]
Suppose a sufficiently fast and resolute FFT was available, though.
What subsequent function counts cycles in a narrow range of FFT bins?
How do you get from an FFT to a regenerated clock?
Tom
Ban
finally a good answer by someone who knows. Take a venerable NE567 or
XR215A, put a bit of amplification and maybe 200Hz highpass in front of it,
so the signal is in the 20 to 100mV rms range. Set the BW to 1% and after
200cycles the output goes low and signalles your PLL locked. You can tap
into the squarewave output to get a stable reference without missing pulses.
K
Ken Smith
John Larkin said:
But it's still effectively a comparator, with its consequences, namely
"capture effect" where big signals blow small signals away.
Yes I agree. The input does act as a comparitor.
K
Ken Smith
No and it I told you where I saw it used ....
