Greetings!
I bought a set of nvg:s of the model PNW-57 as used military surplus. It's a tanker's helmet with attached goggles. I don't know much about electronics, and took them to a friend of mine who knows a lot, but my fault was not finding enough info on the product before taking it to him. There's a box in the back of the helmet that has a line attached to the goggles and a line that goes to the electric system of the tank. Just by looking at the thing (which was made decades ago) my friend thought that the box, which we opened and took out the insides, was a battery unit, so we cut off the line between it and the goggles and tried to attach the goggles to a power source. Nothing happened. After studying the thing more carefully we concluded that it was not a battery but some sort of converter (I'm not a native English speaker nor an electrician so here the terminology fails me), and the device is only to be used with a direct line connection to the tank.
Now, not having a tank and now having cut the line between the goggles and the converter I thought that maybe I could rebuild the converter with integrated batteries. Conversion options I found afterwards suggested that connecting a battery to that box on the back of the helmet would work, but with the severed wires it's an effort and quite frankly I'd like the battery to be inside the box as well if that's at all possible, because otherwise the thing will be cumbersome.
I found these two webpages with circuit pictures of the device:
https://www.circuitlab.com/circuit/dr2hde/pnw-57-switching-power-supply/
http://home.arcor.de/thuernagel/pnw57.html
I sent these to my friend and he asked if there is an explanation or a description on the "function of the coupling/connection". Well, there isn't. He also wondered what the VM3 in one of the pictures is.
Might there be someone on these forums who could make sense of these pictures? My friend said that it doesn't seem to be a difficult build, but we could use some info on how this thing might work... Also I'd like to hear if it can be done at home so that the result will be safe, because what I did understand from my friend looking at those circuits was that there will be quite a bit of voltage in that thing.
