Possible fix: Norton Ghost error 36000 processor general exception
JW
I've now seen two mother boards get this error when running Norton Ghost.
In both of the cases, the problem turned out to be a faulty CPU chip - one
a Pentium 3 850MHz, and the other a Celeron 2.2GHz. For verification, I
Moved the CPU chips to other motherboards, and the problem follows the
chips. I figured I'd post this so it'd be archived for someone else's use.
This is the pertinent part of the error log from the P3-850 machine:
Date : Thu Jan 5 07:25:06 2006
Error Number: (36000)
Message: A GeneralException occurred
Version: 7.50 (Dec 1 2001, Build=335)
Command line arguments:
Active Switches :
No Switches specified in options panel or ghost.ini
ProgMode : PROG_LOCAL
PathName :
DumpFile :
DumpPos : 0
File64 buffersize : 0
FlagImplode : 0
FlagExplode : 0
Mouse IRQ Status : Not in IRQ(0)
Processor exception
Generated at HardExceptionHandlerDjgpp.cpp:314
Program Call Stack
main
sub_main
AttemptOperation
CopyMainline
CopyDiskToFile
WinDiskToFile
WinGetDumpFile
FileReq
Exception code: 0000000e Page fault Error: 0004
Registers:
EAX=00000000 EBX=00000000 ECX=0031a5cc EDX=00000000 ESI=0032145c
EDI=00000000
EBP=002f7ac0 ESP=002f7aa8 EIP=00051c50 FLG=00013246
CS: sel=00af base=10000000 limit=0039ffff
DS: sel=00b7 base=10000000 limit=ffffffff
ES: sel=00b7 base=10000000 limit=ffffffff
FS: sel=00bf base=00000000 limit=0010ffff
GS: sel=00bf base=00000000 limit=0010ffff
SS: sel=00b7 base=10000000 limit=ffffffff
Application stack: 002f8784..00278784
Exception stack: 002786c8..00276788
Call frame traceback EIPs:
0x00051c50
0x0003f36e
0x00040999
0x0003e312
0x000947b6
0x00053a75
0x00033b0a
0x00053a75
0x0003a581
0x000542b7
0x000066a8
0x00092e9c
0x0005a07b
0x0005a3d0
0x000700ad
0x0000220c
0x000024f5
0x00004765
0x00003979
0x001be152
Fat details:
SRC:
FatType..........16
first_sect.......63
ClusterSize......16384
clusters.........51266
root_next_avail..0
data_next_avail..0
dir_sector.......0
root_sector......403
data_sector......435
FAT_sector.......0
NTFS details:
NTFS Global Flags:
contiguousWrite=1 forceDiskClusterMapping=0
inhibitCHKDSK=1 ignoreBadLog=0 ignoreCHKDSKBit=0
enable_cache=0 xfrbuflen=0
last_attr_type = 0
