O
Orc General
- Jan 1, 1970
- 0
I just bought a power inverter from a friend of mine as he doesn't need it
anymore. Its for use in the car, ie. those thing that gives you 120V from
the cigaret lighter plug. Anyway the model is rated at 400Watts puting out
2.6Amps on the label.
I plug it in and having a hand held power drill I immediately plugged it in
to test. I get power of of it and the drill rev up etc. However I notice
as I release the drill trigger, the fault light on the inverter goes on red.
It detected a fault when I disconnect power to the drill. Is this a normal
behaviour?
Another thing, I pulled out my handheld multimeter and tried to read the
voltage from the inverter and was quite surprise to read 400Volts or more.
Which is totally weird.
I don't think this is that high, cause my drill would have burnted out. Can
someone please explain what's going on?
behaviour?
