power supply transformer dead
101
Hi all,
My router has died (SMC Wireless Barricade)... seems to be the power going
into it which is of the type:
kettle lead --> little black box --> lead into router
its the little black box that has died, and the lead that goes into the
router is attached to the box itself (one of those little ones like the end
of a nokia phone charger lead, little bit bigger plug).
the specs are:
Switching adapter,
Input 100-240V 50/60Hz 800mA
Output 12V 1500mA
Is it possible to get a generic one? is this one maybe fixable? or is it
best to contact the manufacturer (SMC)? i am in the UK
thanks
Sam Goldwasser
101 said:
Hi all,
the specs are:
Switching adapter,
Output 12V 1500mA
It's a switchmode power supply. Unless you are into electronics repair, it's
probably best to get a generic replacement. You may have to wire in the
original plug though.
See the Switchmode Repair Guide at the site below if you want to pursue
repair. It may be something simple like a bad solder joint.
--- sam | Sci.Electronics.Repair FAQ Mirror: http://repairfaq.ece.drexel.edu/
Repair | Main Table of Contents: http://repairfaq.ece.drexel.edu/REPAIR/
+Lasers | Sam's Laser FAQ: http://repairfaq.ece.drexel.edu/sam/lasersam.htm
| Mirror Sites: http://repairfaq.ece.drexel.edu/REPAIR/F_mirror.html
Note: These links are hopefully temporary until we can sort out the excessive
traffic on Repairfaq.org.
Important: Anything sent to the email address in the message header is ignored.
To contact me, please use the feedback form on the S.E.R FAQ Web sites.
Michael A. Covington
101 said:
Switching adapter,
Output 12V 1500mA
Generic ones are abundant. Note the 1500 mA (1.5 amp) requirement, which is
rather big... not every 12-volt one will do. Go to your nearest Maplins and
see what they can offer.
