Pro-lite TL-1 LED sign protocol
Tobin Fricke
I recently acquired a moving-message LED sign at a garage sale. It has a
male DB-9 connector that I hope/assume is a serial port by which I can
program the sign. The question is, what is the protocol?
I made a null-modem cable (two female DB9 connectors, with pins 2<-->3,
3<-->2, 1<-->1, and 5<-->5 connected). From a terminal emulator, it seems
that any character I send to the sign is echoed back, no matter what
serial parameters I choose. This leads me to suspect that this port is
not actually an RS-232 serial port. (?) Any ideas?
The sign bears a plaque indicating "Pro-Lite Model TL-1" and also "Model
No. PL-2100W." It appears to be manufactured by U-Sun Electric Co., Ltd.
There is a ROM on board ("P/N A090128") and a Z80 CPU. There is also a
~30 conductor cardedge connector labelled "LOADER INPUT." Maybe
something could be done with that --- I don't have the original
keypad/programmer.
When powered up, the sign displays the message "* STOP MODE *".
thanks,
Tobin
Tim Shoppa
Not all DE-9 serial connections follow what's used on the back of a PC.
If the box and your PC disagreed about which line was ground then it's quite
likely you get the results that you see.
If you can follow the connections from the 9-pin connector to
any RS-232 receivers/transmitters to a UART you may do better. It could also
be RS-422 or even just TTL. (I've seen sign units that used a DE-9
connector to receive 7-bit ASCII parallel data + a strobe !)
Tim.
Tobin Fricke
Why is that? (crosstalk?)
Hmmm. There is nothing obviously UART-like. The traces from the DB9 seem
to head towards a 74LS374 chip (making the "TTL" theory seem a little more
likely), or possibly the Z80 CPU. I'll try to dig up a DMM to check for
sure. There is also a 26-pin DIP labelled "8650" and "V61C16P 15" which is
rather far from the DB9 connector.
Tobin
mike
a male DB-9 connector that I hope/assume is a serial port by which I can
seems that any character I send to the sign is echoed back, no matter
what serial parameters I choose. This leads me to suspect that this
port is not actually an RS-232 serial port. (?) Any ideas?
Ltd. There is a ROM on board ("P/N A090128") and a Z80 CPU. There is
also a ~30 conductor cardedge connector labelled "LOADER INPUT." Maybe
keypad/programmer.
thanks,
Tobin
I modified an XT keyboard to run my Prolite.
Shift register scans the switch matrix directly.
I emailed you what I have.
mike
Return address is VALID.
Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
Wanted GPIB Card for PC.
Bunch of stuff For Sale and Wanted at the link below.
http://www.geocities.com/SiliconValley/Monitor/4710/
K
KimMui
Mike can you let me know what you did to your pro-lite TL-1 as well? I have
one of these and don't know how to get it to display messages. Thanks
KimMui
