Problem with CMOS 4066 and LM311N comparator
leeb_965
Feb 5, 2012
34
I have built the attached circuit and the simulation works the way I wanted it to. When I assembled it on a breadboard I am getting a square wave at the output instead of a rectified AC signal.
Can anyone suggest why this is? The comparator should switch the CMOS 4066 between a positive and negative cycle.
What is the amplitude of your input signal?
Can you confirm the amplitude and shape of the signal output from the first op-amp?
Also, you should do something with the other control inputs on the 4066, they shouldn't be left floating.
leeb_965
Feb 5, 2012
34
The input comes a 3-op-amp instrumentation amplifier. I have two AC inputs from a signal generator of 2.91 pk to pk at input 2 at bottom and 2.75 pk to pk at the top to replicate a full bridge circuit
The difference between the two gives 0.16 which is multiplied by the gain of 21
The input to the Phase Senstive Detector is 3.66 pk to pk
The input to the comparator is an AC voltage of 5.66 pk to pk to replicate the AC bridge excitation voltage and act as the reference signal. The square wave output is input into the switch that outputs a rectified AC signal
The simulation works but on the breadboard the output is a square wave.
Do you have any suggestions as to why this is happening? Do you think the other inputs and outputs should be grounded?
There is some discussion on this page which also talks about the difference between theoretical and practical aspects.
Wabajig
Apr 14, 2012
75
Not sure exactly what your doing. Could you give me specific details of what expect from input voltage and frequency to output. I'm just not getting your application. Unless you got it working, I'm very familiar with these components. Though I don't get on here everyday.
