F
fl
- Jan 1, 1970
- 0
The baking part of my electric oven is out of temperature control. That
is, the temperature is always higher than I set. I find the temperature
sensor on the back of the oven does not hold rigidly. Today, I
unscrewed the four screws of an iron plat in the back of the oven. I
found the thick copper wire from the sensor was loose. And the wire is
a single one, there is a quite some length bare copper wire in a bundle
before the last covered green plastic. I wonder the stick sensor just
conduct temperature, not electrical signal?
The upper four coils work fine. What's the problem with the baking
temperature control?
I did not find the content in the website of
http://repairfaq.ece.drexel.edu/REPAIR/
Thanks in advance
Thanks in advance
