Ranjith
- Jan 1, 1970
- 0
Hello Everyone,
I am facing a problem with extracting the netlist from the mentor
graphics. I am using IC station to build my layout (currently having an
inverter with a signal conditioner and load). When I extract the
netlist using PEX, I get the following
(Only a part of it is shown below)
mM0 IN IN1 VDD VDD P L=4e-07 W=1.8e-06 AD=2.16e-12 AS=2.16e-12 PD=6e-06
+ PS=6e-06 NRD=0.222222 NRS=0.222222
mM1 OUT IN VDD VDD P L=4e-07 W=1.8e-06 AD=2.16e-12 AS=2.16e-12 PD=6e-06
mM2 OUT2 OUT VDD VDD P L=4e-07 W=1.8e-06 AD=2.16e-12 AS=2.16e-12
PD=6e-06
mM3 IN IN1 GND GND N L=4e-07 W=1.2e-06 AD=1.44e-12 AS=1.44e-12
PD=4.8e-06
+ PS=4.8e-06 NRD=0.333333 NRS=0.333333
mM4 OUT IN GND GND N L=4e-07 W=1.2e-06 AD=1.44e-12 AS=1.44e-12
PD=4.8e-06
mM5 OUT2 OUT GND GND N L=4e-07 W=1.2e-06 AD=1.44e-12 AS=1.44e-12
PD=4.8e-06
c_1 1 0 1.1728f
c_2 2 0 2.1136f
c_3 3 0 2.1136f
c_4 4 0 3.0023f
c_5 5 0 3.0537f
c_6 6 0 0.7216f
In the layout I had 4 ports namely IN, IN1, OUT, OUT2.
IN and OUT are the ports of the inverter under consideration.
IN1 is the input to the signal conditioner
OUT2 is the output at the load.
(Signal conditioner and load are similar inverters)
You can see from the netlist, that the capacitors are given as between
1 & 0, 2 & 0 and so on. Its not saying between which ports and ground
or another port with naming them as IN, IN1 etc.
When I run "eldo" it gives me these warnings:
Warning 112: NODE "1": Connected to grounded capacitors only.
This node has been removed from the netlist.
Warning 112: NODE "2": Connected to grounded capacitors only.
Warning 112: NODE "3": Connected to grounded capacitors only.
Warning 29: Set .option MSGNODE = 0 to receive all such warnings.
I suspect that the netlist generated has the errors (which might be due
to the layout, I am not sure about this). If the Ports are mentioned in
the netlist for capacitors, these warnings wont appear. Can anyone help
me why it is generating this way?
Thanks in Advance,
Ranjith
PD=6e-06
PD=4.8e-06
PD=4.8e-06
PD=4.8e-06
c_1 1 0 1.1728f
c_2 2 0 2.1136f
c_3 3 0 2.1136f
c_4 4 0 3.0023f
c_5 5 0 3.0537f
c_6 6 0 0.7216f
Thanks in Advance,
Ranjith
