Programme a remote control 433 MHz from another already programmed
I loking for someone to teache me the way to programme one remote
control 433,92 Mhz for garage door from another one already
programmed. I'm sure it's possible.
Another question is: where I can find any thing to read a logic
programme and do a copy to another remote control?
Thanks for your help.
JorgeErvideira
Skeptic
What makes you so sure it's possible? Perhaps each transmitter is hard
wired with a unique code and it is the receiver programmed to accept the
unique code of the transmitter.
I'm sure because I already observed someone doing. He did a copy from
my neighbours remote already programmed to a new one he sold me.
Jasen
If that one is the same model as your one you have a chance,
if not the process for getting a second opener may be different.
(eg: dominator remotes use a rolling code, and to make a
them work you just introduce the remote to the opener)
the place to gop for the answer is the maker of the opener
or to a locksmith.
Bye.
Jasen
or to a locksmith.
Bye.
Jasen
Ok, I know we can programme on receiver P.C.B. for rolling code:
Locate the programming button inside your Gibidi gate control
enclosure and press it briefly, the LED will flash on the receiver
P.C.B.
With the new transmitter and press the button that you wish to use to
operate your receiver for one second.
Programming is now complete and your new handset should now operate
your receiver.
But sometimes change the others one's already programmed, that's
because I'm looking for the other way to programme.
Jorge
