programming a bios eeprom through serial or parallell port?
bart bervoets
Is it possible to make a bios eprom programmer, and what software can i use,
what types
to program...
Bart Bervoets
Rein Wiehler
what types
to program...
Bart Bervoets
yes
is the eprom a flash type? yes or no
is the eprom or flash, what ever it is, removable from
the mainboard?
if not removeable can it be programmed on the motherboard?
do you have the number ?
are you going to build a progarmmer?
is the softwre you want to progam into the device in the right format
for your programmer?
etc etc.
have fun
rw
rstlne
what types
to program...
Bart Bervoets
Yea, Serial..
Course you cant just connect the pins of the chip to the serial port.. if
that's what your asking
LanceBro
Depending on your bios some bios' have built in protection on a failure to be
reflashed using the floppy drive in your computer to flash it. Leaving it on
the motherboard. This is on a failed upgrade or just on a failed bios.
check with your bios manufacturer to see
if your bios supports this.
Gary Tait
Whereas On Wed, 1 Oct 2003 23:25:27 +0200, "bart bervoets"
Yes.
The software made for that design, or if you are going to design it
yourself, you will have to write your own software.
what types
to program...
Just about any type the commercial programmers will.
Anonymous
You can obtain the schematics and the software needed to program eeprom
chips though a parallel port at www.batronix.com. However, without
registering their software you can't fully program an entire chip.
If you don't want to spend any money to use their software, I can provide
you with a key generator such that you may use their software for free.
However, I remind you that it is illegal to use a program to generate a key
such that you may use copyrighted software for free. I further accept no
responsiblity for you using the program I provide. Those that are interested
may post a reply to this message.
