programming PIC16f877 using all-11
shehry
hi,
i cant seem to be able to burn my code properly (i am not sure but i
think that this is the problem). i used pcwh pic c compiler to write my
code, which does nothing but turn a few ports on. i compiled the code
and used waccess software with all 11 programmer to burn the hex file
generated.
now this is where i think the trouble seems to come in. when i try to
load the hex file in to the buffer i am prompted to select the file
format and i have the following options:
1. Binary
2. Intel Hex
3. Motorola S Record
4. PICES HEX
5. 8Bits INHX8M
6. 16Bits INHX16
i used pices initially, but it didnt work. then i tried all the rest of
them. it didnt work.
can anyone help me in this context. i am attaching the code too
although its just a test:
#include <16F877.h>
#device *=16 ICD=TRUE
#fuses HS,NOWDT,NOPROTECT,NOLVP
#use delay(clock=12000000)
#use rs232(baud=9600, xmit=PIN_B0, rcv=PIN_B1)
void main()
set_tris_c(0x00);
set_tris_d(0x0f0f);
delay_ms(10);
output_d(0x79);
output_high(PIN_A0);
while(1)
printf("helloooo dolly");
delay_ms(1000);
output_c(0xaa);
Spehro Pefhany
hi,
generated.
1. Binary
2. Intel Hex
4. PICES HEX
5. 8Bits INHX8M
6. 16Bits INHX16
Just out of curiosity, what kind of object file (8-bit hex, 16-bit hex
or binary) have you asked your compiler to output?
<snip>
I'm not familiar with CCS, but this looks like it might have problems.
Why 12 bits for the TRISD register, for example?
Didn't the compiler vendor supply a known-working blink an led "hello
world" demo program?
Best regards,
Spehro Pefhany
Roger Hamlett
shehry said:
hi,
generated.
1. Binary
2. Intel Hex
4. PICES HEX
5. 8Bits INHX8M
6. 16Bits INHX16
#include <16F877.h>
void main()
set_tris_c(0x00);
set_tris_d(0x0f0f);
delay_ms(10);
output_d(0x79);
while(1)
delay_ms(1000);
output_c(0xaa);
PCWH, can develop both 8 and 16 bit file formats. In your main screen,
select 'options', 'file formats'. The screen displayed sets the hex output
format, in the tick boxes at the top right. The 16bit format, is the
normal one, and is the format referred to above as 'INHX16' (Intel Hex
extended 16bit), while the 8bit format is 'INHX8'.
There are quite a few 'comments' about the example code though.
The file to be programmed, will be called 'filename.hex', where
'filename.c' is your source code name.
You are setting the TRIS registers, but the compiler _by default_, will
run in 'standard IO' mode, where it generates TRIS controls as ports are
accessed. If you want to use TRIS yourself, select 'fast_io' for the ports
concerned. Look in the manual for this.
You are setting 'ICD=true'. Beware. If you do not have the ICD control
pins properly loaded, this will stop the chip running.
Are you sure your crystal is suitable for the chip?. If your chip has
a -04 suffix on the part number, it is a 4MHz part, and though these will
operate up to 10MHz on higher supply voltages, these do not support 12MHz.
Have you got MCLR pulled up to 5v?.
Have you got both supply connections made?. The chip does need them.
Best Wishes
F
Frank Bemelman
shehry said:
hi,
generated.
I'm almost sure that pcwh produces intel hex format.
You should be able to see "helloooo dolly" somewhere in
the hex dump window of your programmer software. If not,
you loaded it with the wrong file format for sure.
shehry
thanks a lot to all of you...especially to you roger. you removed some
of my confusions concerning the tris register. but this time actually
the problem was something else. i accidently inserted a 330pf capacitor
instead of a 33 pF one :( .
thanks a lot to the rest of you too...you're all great :)
Roger Hamlett
Those zeros, are sent to get you!....
Best Wishes
