Project understanding
ami85t
Feb 19, 2014
71
HI all,
I'm trying to understand (and remember) whats going on in this project
which I intend using:
http://www.micro-examples.com/articles/index.php/PicoDetector#comment=1:99
I will be grateful to anybody how can help me with a few issues:
1. In the explanation appears:
"Coil L1 replaces crystal in PIC oscillator circuit"
what exactly does that mean?
As far as I understand the method for detecting a metal is by a AC current passing
through a inductor and/or capacitor. What oscillates the current in this circuit? an
initial oscillator of the pic? if yes so isn't it supposed to be a square
signal? if the answer is again yes - does the circuit work, does the
inductor respond to a square wave?
2. I don't manage to understand which type of inductor to use
for this type of project. I sow a few different types which made
me confused:
- http://malaysia.rs-online.com/web/p/inductor-leaded/2335409/
- surface Inductor ?
3. About the code:
Recently I did a project which contains a pic16f877 and
for that purpose I wrote in assembly language and used Mplab environment and ICD2
For burning the code to the pic.
can I use the same method here by copying the text of the code and use in the same
method? (by changing the configuration of Mplab to C code)
Thanks, Amitai
A crystal is normally used as part of an oscillator to set the PICs operationg frequency. In this clever little project, it has been replaced by a coil. The oscillator still operates, but now its frequency is dependent on how much metal is close to the coil, becuase that will change the inductance of the coil. This fequency is then compared to another frequency that comes from the internal oscillator for the watchdog timer. The PIC can then sense a change in it's clock frequency, and hence the presence of metal near the coil.
You will have to install the C compiler from Microchip, then you can compile it and program the chip from MPLAB as you did with your assenbly language program.
ami85t
Feb 19, 2014
71
I build this project up and for some reason it doesn't work.
I used a PIC16f877 and translated the code to Assembly.
I'm suspecting its a problem in the code. ( I checked the circuit and everything seems OK).
can anyone help me with this one?
Thanks, Amitai
LIST P=PIC16F877
include <P16f877.inc>
org 0x00
reset:
nop
goto start
org 0x20
start:
; configuration
bcf STATUS,RP0 ;bank 0
bcf STATUS,RP1
ctr EQU H'0025' ; number of loops between two watchdog resets
previous EQU H'0026' ; previous value of ctr
calibr EQU H'0027' ; calibration value when oscillator runs free
restarts EQU H'0028' ; number of watchdog restarts
en EQU H'0029' ; enable flag, allows detection
bsf STATUS,RP0 ;bank 1
clrf TRISB ; making PORTB output
clrf PORTB ; reset output
; end configuration
;*************** MAIN PROGRAM *****************
main_loop:
btfss STATUS, 4 ; POWER UP? WDT TIME OUT OCCURRED?
goto init_loops ; yes
goto check_reset_counter ; no
init_loops:
clrf restarts
movlw 0x01
movwf calibr
check_reset_counter:
movlw 0xFF
subwf restarts, w ; restarts - 255
btfss STATUS, C ; restarts =< 255 ?
incf restarts, f ; yes - increment restarts
movf previous, w
xorwf ctr
subwf calibr, w ; calibr - ( previous xor ctr)
btfss STATUS, C ; is previous XOR ctr > calibr ?
call metal_detcted ; yes
movf ctr, w
movwf previous
movlw 0x0F
subwf restarts, w ; restarts - 15
btfsc STATUS, C ; calibration over?
goto calib_over ; yes
goto calib_still_active ; no
calib_over:
bcf PORTB, 1 ; calib led OFF
movlw 0xFF
movwf en ; enable detect led
goto WDT_set
calib_still_active:
bsf PORTB, 1 ; calib led ON
clrf en ; disable detect led
goto WDT_set
WDT_set:
movlw 0xF9
movwf OPTION_REG ; Prescaler Rate, PORTB pull-ups are disable? (needed)?
clrf ctr
waiting_loop: ; start counter, to be interrupted by watchdog
btfss STATUS, 4
goto main_loop
incf ctr, f
goto waiting_loop
metal_detcted:
bsf PORTB, 2 ; turn led detect ON
btfss STATUS, 4 ; time out occurred ?
goto led_off ; yes
goto calib_check ; no
led_off:
bcf PORTB, 2 ; turn led detect OFF
return
calib_check:
movlw 0x0F
btfsc STATUS, C ; in calibration mode?
return ; no
rlf calibr
call DELAY_1m
call DELAY_1m
call DELAY_1m
call DELAY_1m
call DELAY_1m
return
;*************** END MAIN PROGRAM *************
DELAY_1m:
movlw 0x2f ; N1 = 47
movwf 0x35
cont2: movlw 0x10 ; N2 = 16
movwf 0x36
cont1: decfsz 0x36,1
goto cont1
decfsz 0x35,1
goto cont2
return
end
jpanhalt
Nov 12, 2013
426
It will be easier to read, if you use code tags {code} code {/code} (Replace the curly brackets with regular brackets).
Code:
LIST	P=PIC16F877
org	 0x00
reset:
nop
goto	start
org	 0x20
start:
; configuration
bcf	 STATUS,RP1
; end configuration
main_loop:
init_loops:
clrf	 restarts
movlw	 0x01
movwf	 calibr
movlw	 0xFF
movf	 previous, w
xorwf	 ctr
movf	 ctr, w
movwf	 previous
movlw	 0x0F
calib_over:
movlw	 0xFF
goto	 WDT_set
calib_still_active:
goto	 WDT_set
WDT_set:
movlw	 0xF9
clrf	 ctr
btfss	 STATUS, 4
goto	 main_loop
incf	 ctr, f
goto	 waiting_loop
metal_detcted:
goto	 led_off	 ; yes
led_off:
return
calib_check:
movlw	 0x0F
return	 ; no
rlf	 calibr
call	 DELAY_1m
call	 DELAY_1m
call	 DELAY_1m
call	 DELAY_1m
call	 DELAY_1m
return
DELAY_1m:
movwf	 0x35
movwf	 0x36
goto	 cont1
decfsz	 0x35,1
goto	 cont2
return
end
Apparently you set the configuration with your compiler. It would help is you showed it here. Since the 12F and 16F are different, please show your schematic.
I see where you set your outputs, but not where you turn off the analog inputs and comparators. Here is how it was done for the 12F683:
Code:
   CMCON0 = 7 ;
    ANSEL = 0 ;
John
Edit: Attached as Notebook text -- hopefully easier to read
View attachment 877 code.txt
ami85t
Feb 19, 2014
71
I added the schematic capture.
As far as I see only ports A and E can be analog
and my output is via portB. the related registers to portb
are the trisb and option reg which I referred to.
About the comparators: as far as I understand there's no need to
relate to them, (in the original code the CMCON0 statement disables the comparator)
since the measuring is the change since the last WDT end, no?
I was thinking that maybe the problem is connected to the
code conversion of the WDT and the and power-up.
Code:
LIST	P=PIC16F877
org		0x00
reset:
	nop
	goto	start
	org		0x20
start:
; configuration
	bcf		STATUS,RP1
; end configuration
main_loop:
	init_loops:
		clrf		restarts
		movlw		0x01
		movwf		calibr
		movlw		0xFF
		movf		previous, w
		xorwf		ctr
		movf		ctr, w
		movwf		previous
		movlw		0x0F
	calib_over:
		movlw		0xFF
		goto		WDT_set
	calib_still_active:
		goto		WDT_set
	WDT_set:
		movlw		0xF9
		clrf		ctr
		btfss		STATUS, 4
		goto		main_loop
		incf		ctr, f
		goto		waiting_loop
	metal_detcted:
		goto	    led_off					; yes
	led_off:
		return
	calib_check:
		movlw		0x0F
		return								; no
		rlf			calibr
		call		DELAY_1m
		call		DELAY_1m
		call		DELAY_1m
		call		DELAY_1m
		call		DELAY_1m
		return
DELAY_1m:
		movwf		0x35
		movwf		0x36
		goto		cont1
		decfsz		0x35,1
		goto		cont2
		return
end
jpanhalt
Nov 12, 2013
426
"Doesn't work" can mean a lot of things. For example, it could mean it doesn't compile, it doesn't detect metal, and so forth. Can you describe what you mean?
Have you simulated the program?
John
ami85t
Feb 19, 2014
71
sorry, I'll try and be more specific.
The compilation and programing of the code and the PIC are fine.
When I connect the pic to the circuit nothing happens.
The outputs of the B port stay '0'V logic.
Amitai
Most likely your PIC is not running. You need to set various configuration bits, and you should do this in the code.
ami85t
Feb 19, 2014
71
I got some code correction advise and now using a DMM I can see that the frequency on the inductor changes while having metal near,
but the led doesn't respond at all. the output of both the legs is
'0' continuously.
Amitai
new code:
Code:
	LIST P=PIC16F877
	__CONFIG _LVP_OFF &_WDT_ON &_PWRTE_ON &_CP_OFF & _HS_OSC
	; basic config values  Watchdog ON, Lvp OFF, XT OSC crystal 4mhz and below
	cblock 0x20	; define user registers/variables
	ctr  		; number of loops between two watchdog resets
	previous	; previous value of ctr
	calibr  	; calibration value when oscillator runs free
	restarts 	; number of watchdog restarts
	en 			; enable flag, allows detection
	endc
	org 0x00
	nop
	goto start
start:
	; configuration
	banksel  TRISB
	banksel	 0		 ;bank 0
	; end configuration
main_loop:
init_loops:
	clrf restarts
	movlw 0x01
	movwf calibr
	movlw 0xFF
	movf previous, w
	xorwf ctr
	movf ctr, w
	movwf previous
	movlw 0x0F
calib_over:
	movlw 0xFF
	goto WDT_set
calib_still_active:
	goto WDT_set
WDT_set:
	movlw 0xF9
	clrf ctr
	btfss STATUS, 4
	goto main_loop
	incf ctr, f
	goto waiting_loop
metal_detcted:
	goto led_off ; yes
led_off:
	return
calib_check:
	movlw 0x0F
	return ; no
	rlf calibr
	call DELAY_1m
	call DELAY_1m
	call DELAY_1m
	call DELAY_1m
	call DELAY_1m
	return
DELAY_1m:
	movwf 0x35
	movwf 0x36
	goto cont1
	decfsz 0x35,1
	goto cont2
	return
	end
