proposed circuit for bicycle battery recharger
  • Thread starter Tom (at tomsweb.net)
  • Start date
Everyone,
Based on suggestions from the previous thread I came up with the
following simple circuit for charging 4 NiMH cells from my dynamo, it
is a full-wave voltage doubler with Schottky diodes:
4700uF
.------------|---o--||----o-->|--o-----o-------------.
( ~ ) GND|-o | | | --- --- 4 cell
dynamo '-' | | | | --- 4700uF - NiMH
2.5-5V | - .-->|--|-' | | --- (4.8V)
RMS | ^ | | | | -
'------------|---o--||--o---->|--' | |
4700uF | |
GND GND
created by Andy´s ASCII-Circuit v1.24.140803 Beta www.tech-chat.de
All diodes are schottkies. I simulated this and it appears to work
relatively fine for the expected voltages >=2.5V RMS. The NiMH
batteries are fed a ripply and unregulated rectified DC and I am
relying on the cells themselves to regulate this to their required
voltage (the theory is that when the voltage wants to go higher, the
batteries will demand more current and limit the voltage, and vice
versa).
Any opinions about whether this simple circuit will work? Will my NiMH
batteries like it? I realize I will have to make sure the batteries are
not overcharged.
FYI, a quick repeat of the specs of the dynamo:
* biking speed 10 km/h: 5.6VRMS unloaded, drops to 2.5VRMS at 0.5 amp
load, available power 1.25W
* biking speed 20 km/h: 9.9VRMS unloaded, drops to ca. 4VRMS at 0.5 amp
load, available power 2W
* did not measure the AC frequency but I expect it to be in the range
10..200 Hz, and pretty much sinusoidal
greetings,
Tom
Ross Herbert
Everyone,
4700uF
RMS | ^ | | | | -
4700uF | |
GND GND
I am not too impressed with the way the schematic appears. What are
those two devices directly across the dynamo with the GND between
them?
If they are meant to be diodes then on every alternate half cycle they
will place a short directly across the dynamo output.
them?
Oops, sorry, the bottom diode should have been the other way round.
Messed it up when translating my schematic to ASCII. Corrected
schematic:
4700uF
2.5-5V | V .-->|--|-' | | --- (4.8V)
RMS | - | | | | -
4700uF | |
GND GND
This doubler circuit I found at:
http://www.kwarc.org/bulletin/99-04/tech_corner.htm
greetings,
Tom
Ross Herbert
schematic:
That's better, should work....
F
Fred Bloggs
Tom said:
4700uF
RMS | - | | | | -
4700uF | |
GND GND
What's the matter with the conventional full-wave doubler, not enough
diode drops? :
View in a fixed-width font such as Courier.
.. dynamo
.. 2.5-5V
.. RMS
.. .-------+--o-->|--o---+---------------o-------------.
.. '-' | --- 4700uF |+ --- 4 cell
.. | | | --- - NiMH
.. '---------------------+ --- 4700uF --- (4.8V)
.. | --- 4700uF | -
.. +--o--|<--o---+---------------+-------------+
.. GND
diode drops? :
You're right, that circuit is more efficient at low input voltages
because of fewer diode drops - thanks.
greetings,
Tom
John Smith
Tom:
I would think that "shunt regulator" does nothing to improve the effort
needed to peddle the bike...
John
mike
diode drops? :
. dynamo
. 2.5-5V
. RMS
. | | | --- - NiMH
. | --- 4700uF | -
. GND
Please explain the purpose of the rightmost cap????
Then explain why we need ANY of the caps????
Depending on the load vs available charge current, there may
still be the problem of overcharging and the pedaling effort
to just overheat the batteries.
Then there's overdischarging...
mike
Return address is VALID but some sites block emails
with links. Delete this sig when replying.
Wanted, PCMCIA SCSI Card for HP m820 CDRW.
FS 500MHz Tek DSOscilloscope TDS540 Make Offer
Wanted 12" LCD for Compaq Armada 7770MT.
Bunch of stuff For Sale and Wanted at the link below.
MAKE THE OBVIOUS CHANGES TO THE LINK
ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
Dr. Sisyphus Frankenstein
John said:
Tom:
It does if the lamp is prevented from burning out (otherwise you crash
in the dark).
John Smith
ahhh, I see, so the shunt kicks in, causes to great a load to be able to
pedal against and the bulb is saved!!!
.... are you for real, or you just don't think--possibly not understand
what you read?
John
F
Fred Bloggs
Pleas explain how you can double the dynamo voltage without ANY caps????
If the dynamo wasn't the dynamo, the two series caps can function as
ballasts, limiting the current. But the dynamo is all wrong for this,
increasing output voltage with frequency.
Right- he needs to put an N-Channel in series with the return to doubler
and cut this off when the average Vbatt indicates full charge. That
would be an LMV431 type circuit with zero drain when the dynamo is not
charging the capacitors. Why don't you draw that up????
I wouldn't worry about that- if the lights are a safety issue then you
don't want them to shut off.
mike
As I stated in my first post on the subject, you don't need to double
the voltage. You need to put the load where the voltage exists. All
you need do is split the battery into two pairs
of cells and put them where the series caps are. Delete the third cap too.
HUH?? I'll need another (different) expression of the above sentence???
This has been used in motorcycles for decades...almost a century. The
source
is inductive, so the increased output at higher frequencies is
mitigated by the inductance. If it's not enough, you can always
add more.
mike
what you read?
Hey dumbass,
How would *any* lighting system "improve the effort needed to peddle the
bike?" I own generator/light systems that have shunt regulators
built-in, with no modification. What do you know about the generators
built for bikes? You think some 1/2 or 1 watt zener means squat in
terms of the power needed to pedal a bike? Even a slacker can put out a
100 watts with little problem. LANCE can put out over 400 watts for > 1
hr straight. The shunt is cost effective protection, not perfection,
and not important in terms of total efficiency.
And what is with the stupid top-posting?
F
Fred Bloggs
That works, but if you add current limiting then you will need two
circuits in place of one.
In half wave, those stacked caps act as resistors of value 1/(8*F*C)
IIRC in so far as determining the average output DC voltage.
John Smith
.... my gawd, perhaps someone in this room will take pity on you and
explain to you what an A$$ you have just made of yourself...
I might of, but ya pi$$ed me off... <grin>
John
F
Fred Bloggs
make that 1/(2FC)
