Protecting my arduino against high voltage spikes?
H
h
Newbie, I'm afraid, though I'm not doing badly so far.
I've built a digital speedo with an arduino and some LED displays. It picks
up pulses from a hall-effect device I've stuck by the drive train of my
truck. Currently, the output of the device (which handily bounces between 0
and 5v) is connected straight to an input pin on the arduino, but I'm
concerned that because the wire runs near the high-voltage ignition cables
for the engine, it may pick up some spikey noisy stuff - is there a basic
way I can protect my arduino from trouble?
Many thanks
h
Tom Biasi
picks up pulses from a hall-effect device I've stuck by the drive train of
my truck. Currently, the output of the device (which handily bounces
between 0 and 5v) is connected straight to an input pin on the arduino,
but I'm concerned that because the wire runs near the high-voltage
ignition cables for the engine, it may pick up some spikey noisy stuff -
is there a basic way I can protect my arduino from trouble?
Many thanks
h
You could start by using grounded shielded cable.
Tom
Jasen Betts
connect a 100K resistor between the end of the wire and the processor
pin. if you're picking up noise from the ignition add 10nf from the
chip's input pin to ground.
default
Many thanks
h
Input protection diodes are common on most pics, but it wouldn't hurt
to have a pair of external ones to suppress above supply and below
ground spikes.
Your power supply should also be safe for automotive use.
