Protel Autotrax and Win98
Richard Hosking
I have a (licensed!) copy of Autotrax which is now a bit long in the tooth,
but still works OK.
It has run happily under W95 for years, but I want to put it on a newer
computer with W98 - there sems to be problems with video drivers. The best I
can get is low res CGA
Anyone have later video drivers for this?
Richard
Alan
but still works OK.
Richard
Richard
Have a look at:
http://www.airborn.com.au/layout/easytrax.html
HTH
Alan
Jenal Communications
Manufacturers and Suppliers of HF Selcall
P O Box 1108, Morley, WA, 6943
Tel: +61 8 9370 5533 Fax +61 8 9370 5106
Web Site: http://www.jenal.com
e-mail: http://www.jenal.com/contact.php
Richard Hosking
Many thanks for this
It will regenerate the old program
It looks like there is a better output option file as well for plotting to a
laser printer.
Richard
Richard Hosking
I have managed to get the program running well under W98, but now I find the
schematic libraries are reported as a "bad file format" and they wont load.
This in spite of reloading the libraries from disk. Has anyone faced this
problem? Was there a solution?
Richard
Chaos Master
*I think* it's caused by a FAT32 file system or long file names, or installing
in a big hard drive. Or the files may be just corrupted.
Richard Hosking
I reinstalled from the original disk - so they should not be corrupted. I
have an 80GB drive - I guess that could be relevant. Filenames are the same
as original - not longer than 8 characters. Any ideas on solutions?
Richard
Apollo
I run autotrax, and autotrax schematic, with libraries
for both - there is definitely no problem with long file
names, or having the programs on a large drive (etc).
However, the libraries for protel autotrax and protel
schematic are seperate, just like the PCB editor and
schematic editor programs themselves - and if you try
and load the library using the wrong program you will
get the error you describe.
I have a list of other stuff to watch out for! ...
http://www.airborn.com.au/layout/autotbug.html
Regards
Steve
Similar threads
Replies
3K
Kendall Castor-Perry
K
W
Replies
4
7K
ChrisGibboGibson
