Protel to Specctra
Designer2004
Hi
I have exported many pcbs from Protel 99 to specctra to auto route.
The problem i have is that i can not export GND and power nets to
specctra correctly to cause specctra treat these nets differently.
Does anyone have experience in this problem?
Regards
Anton Erasmus
Hi
The Protel 99 to/from specctra interface is a very limited
interface. Only the bare basics are supported. Anything else you
have to edit/setup directly in specctra.
The interface between Protel/Specctra has not improved one bit from
what I could see in the Demo of the latest Protel product.
Regards
Anton Erasmus
Designer2004
Hi
Thanks for your reply.
Would you please suggest me other methods to do that( such as using
other softwares)?
Regards
Designer2004
Hi
Would you please suggest me other methods to do that(such as using
other tools)?
Regards
Leon
Designer2004 said:
Hi
other softwares)?
You could try Electra:
http://www.connecteda.com/
It's written by someone who used to work on Specctra. It's very good.
Leon
Anton Erasmus
Hi
other softwares)?
There might be better Protel 99 to/from Specctra filters available. If
you can find such software I would expect it tobe quite expensive.
When I had to have more control on routing and nets, I did it manually
in specctra. Although this is time consuming, it works and is
possible.
Regards
AJ Erasmus
