thomasfb
- Jan 1, 1970
- 0
Dear Reader!
As an example I try to perform a parameter sweep
of a simple voltage divider (R1 and R2 in series to a 10V DC voltage).
One of the resistors shall be the parameter. The divided voltage I
called Vout.
I set up circuit, assigned to one of the resistors the
value {Rtune}, put the component PARM, set there
the name to Rtune and assigned there also the value 30.
In the analysis setup, marked are the Bias Point and the
Parametric buttons. In the Parametric options I assigned
Global Parameter, Name=Rtune and set there Start Value=30,
End Value=100 and Increment=2.
After starting the analysis: no error - simulatin complete.
But I cannot see any possibility to make the following graph:
(Vout versus Rtune)
Also I didn't see how to display a data table (Vout,Rtune)
P.S: In the analysis setup, when I additionally mark the
transient analysis, I can display Vout versus time, and
Rtune as the parameter. But it is ugly to see horizontal
lines, and time is no information in my case.
Anybody there who knows to solve this problem?
Thanks in advance for your efforts.
Cordially
Thomas
called Vout.
(Vout versus Rtune)
Cordially
Thomas
