PTT Microphone switch wiring
lukester
Nov 6, 2006
4
I purchased this old PTT mic which had no wiring at all.
I wired it directly, bypassing the switch and it does work. Now, I'm trying to figure out the switch on this thing :-X
As I said it's a push-to-talk; it has 2 terminals and 1 wire.
1- When I put a continuity tester on both terminals and push the switch, the light goes on.
2- When I put a continuity tester from terminal (a) to the wire & push the switch, the light goes off.
3- When I put a continuity tester from terminal (b) to the wire, the light is off & when I push the switch, the light stays off.
The mic has a balanced wire.
Hope someone can help, thanks!
lukester
Nov 6, 2006
4
OK. Now, how do I connect this?
I've got the mic wire and the cable wire both going to the switch, both balanced (ground, hot, cold)
:eek:
