Rene
- Jan 1, 1970
- 0
Hello to all!
I have a question that may sound stupid to one who knows the answer but
I am bit uncertain about whether what I would like to do would be a wise
thing. For some time now (I have not much time to spend on my hobby) I
have been building an experimentation board for AVR processors, quite a
sophisticated one if You ask me (it's my own design)
. Often one sees
that output leds are coupled directly to the output ports (well, with a
resistor off course). I did not like that so I chose to use 74HCT540 bus
drivers (they sink the current through the led so the latter lights up
when there is a one on the bus). The bus is 18 lines wide (plus two for
PS) and which line has which function depends on the adapter that is
plugged in (it holds the controller)(btw for LED 17 and 18 I use two
ports from a 74HCT04 in case someone would wonder how to buffer 18 lines
with 2 octal buffers). The problem is that when a line is "not defined",
it's led turns on. And sometimes off. And on. And so forth... Point Your
finger to it and it will do something. The impedance of those drivers is
obviously extremely high. I noticed that if I use a pull-down resistor
of 1Mohm on every line, this unwanted behaviour does not occur. However,
the datasheet of several AVR-processors says that it is not allowed to
put more than one gate (a HC-buffer) on the oscillator output (XTAL2) of
the processor if one is using an external crystal. In a datasheet with
general specs of the 74HC family I found that input leakage current is
maximum 1 uA, at 25 degrees C even only 0.1 uA. They tested this with a
VCC of 6 volts. That means an impedance of 6 MOhm and that is more than
my 1 MOhm.
My question is whether anybody foresees problems when I mount these
resistors. Off course there might be a problem if I want to measure an
analogue voltage from an high-impedance source (the impedance of the ADC
is, iirc, about 32 MOhm) but in that case I will have to buffer it, no
problem. But what are Your opinions, apart from that? And when some line
of the bus will be connected to the crystal, do You think that in real
life that will cause problems? I can off course make some of these
resistors "disconnectable" by means of jumpers (I wish I had done that
with the leds, but then again, then You just wouldn't see them anymore,
the buffer might still start oscillating), but as I can connect several
diff. types of controllers through the adapters, it would mean more
jumpers than for just one type of controller.
Thank You very much in advance for Your opinions/experiences.
Yours sincerely,
Rene
P.S. I just thought of what might a smarter solution to the crystal
problem, if I want to use a controller with an external crystal I can
put the jumper on the specific controller adapter so that the line will
not be connected to the bus on the development board. I guess that would
be best. Remains the question whether there could be other problems.
P.P.S. I could have rewritten my question after my brainwave from the
first P.S. but in that case someone might have come up with a suggestion
about that the crystal might give problems, I thought it would be wiser
to just leave it like this so You might see that those specific pins
won't be a problem anyhow.
my 1 MOhm.
Yours sincerely,
Rene
