N
Natty
- Jan 1, 1970
- 0
hello friends,
I need ur help. I am using a PIR detector (IRA-E700STO SERIES MURATA)
I dont get any changes in the output voltage when an infrared body
is detected.. the output voltage ust produce a transition from either
+ve to -ve or from -ve to +ve.. I dont get that..
A PIR detector has an inbuilt FET. the pinout of the detector is the
Drain, Source and the Ground.
The detector is powered by supply connected to the drain.. and the
out put from the source is used for further analysis. I am a bit
confused.. I am not sure if something is wrong with the detector. I
wud really appreciate ur suggestions. thanx in advance.
Natty.
Natty.
