Question about design of clocking circuit
U
usao
Disclaimer: I am not a student, but a home hobbyist trying to work out
a problem.
Here's the situation. I have a 1Mhz osc which I want to switch on-off.
The issue is that I don't want the on-time of the clock to change
depending on when the switch is thrown.
Im looking not for answers, but for pointers or suggestions on how I
should work this problem. The angle I have tried so-far is to use a
edge triggered flip-flop to catch the output of the input osc ANDed
with the switch input. The idea here is that if I catch the edge, and
it's active, then I can send this through a one-shot, or somthing else
to keep the width of the pulse the same size.
However, this seems kind of complicated, and may require a debounce on
the switch as well...
Is there some simpler approach im missing?
Ron (rwatkins at dssolutions dot com)
Rene Tschaggelar
a problem.
Yes, you just have to synchronize your on/off with the clock with a FF.
Rene
Activ8
a problem.
HArd to say without more osc circuit details but I'm quessing this
osc is made with inverters (?) Why not use a SPDT or dpdt switch
with one side to turn on the OSC supply and the other (when off) to
ground out the timing cap to return it's initial condition to 0V?
K
Ken Smith
a problem.
Clk in
! NOR -------- Output
! DBSW !--------! !
! ----------!D ! !
------------!Clk ! !
! Q/ !----------
DBSW = debounced switch
You can use the other section of a dual FF to debounce the switch.
Lasse Langwadt Christensen
Rene
it can be done even simpler with a latch,
____ ___
gatesignal --------|D Q|--------| |
| | | & |---- CLKout
| | +---|___|
CLK ---------+----o|LE | |
| |____| |
-Lasse
Rene
its even simpler with a latch
____ ___
gatingsignal ---------|D Q|------| |
| | | & |---- Gated CLK
CLK --------------+--o|LE | +--|___|
| |____| |
Lasse
