Cass Lewart
- Jan 1, 1970
- 0
The inexpensive FRS/GMRS walkie talkies operate on up to 22 channels,
each with selectable 38 subchannels.For example, channel 1 has an
assigned frequency of 462.5625 MHz. The same frequency seems to be used
on all subchannels. If I set one walkie talkie to channel 1, subchannel
0, or a scanner to 462.5625 MHz I can listen to transmissions from
another walkie talkie set to channel 1 and any of the subchannels (0 -
38). However, if the receiving walkie talkie is set to channel 1,
subchannel 10, then the transmitting walkie talkie also has to be set to
channel 1, subchannel 10. My question is how does the walkie talkie tune
out other subchannels?
My feeling is that the walkie talkies use some kind of TRF with an
active low pass filter. BTW is it possible to implement IF type band
pass filters (10.8 MHz, 200 kHz bandwidth, or 455 kHz with 10 kHz
bandwidth) using active components and capacitors without inductors? I
was unable to find any schematics of Walkman or walkie talkie type
receivers.
_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/
_/ Cass Lewart Voice (732) 264-9541 Fax (630) 566-0349/_/
_/ e-mail: [email protected] _/_/_/_/_/_/_/_/_/_/_/_/_/
_/ N 40 deg 23' 41.9", W 74 deg 11' 29.7"/_/_/_/_/_/_/_/_/
receivers.
