Question about static electricity
I bought a USB drive, and it came in a small plastic shell package.
Is it safe to assume that this plastic material is anti-static?
I have not yet opened the package, and I left it sitting on the carpet
for a while. Then I did some vacuuming, and ran the vacuum cleaner
right next to the package.
Assuming that the plastic package is anti-static, would that be enough
to prevent the USB drive from being damaged by any static electricity
generated from the carpet or the vacuum cleaner?
neon
Oct 21, 2006
1,325
It has nothing to do with vacuum cleaner or the closesness of power cord. It has everything to do with friction causing eletrostatic voltage. safe ground youself to the case of the computer while opening the package whatever static you have accumulated will be gone as soon as you touch the case of the PC. I asume your PC is properly grounded.
Z
z
most places north of the equator, static is more of a problem during
the dried out winters than the muggy summers.
table.delete
Being that the amount of static that may build up on the packaging is
unlikely to kill you, your assumption is safe... however the same case
may not be true for the USB drive... although most drives are quite
resistant to static damage, you've given us no information about your
drive, so we'll assume the worst case. :)
If the package is indeed anti-static, the drive should be relatively
safe from static damage, as long as you open it with care, that is,
ground yourself before opening the package! Touch a grounded (bare)
metal object for a few seconds before opening the package and you
should be safe.
If it is not, the package may have accumulated some charge which
should be dissapated before you open it. Try touching a grounded
metal object while touching the package for a few seconds... that
should take care of most of any charge on the package.
I
ian field
My USB stick lives in a pocket with various other junk (keys etc), the
protective cap frequently falls off - its been carried about in my pocket
for over a year and still works fine.
neon
Oct 21, 2006
1,325
just because you are un-knowladgable doesn' t means the rest of us should be like mushroom fed bullshit and kept in the dark. I don't know maybe this industry don't know what are they doing spending money on worthless protection.
neon
Oct 21, 2006
1,325
z said:
On Jul 7, 11:40*am, "[email protected]"
> for a while. *Then I did some vacuuming, and ran the vacuum cleaner
ever wander why?
W
whit3rd
It is not. Static charge is sufficient to cause voltage overstress
on some high-impedance MOS devices, but USB doesn't
have any connector pins attached to high-impedance
circuitry, only to transceivers ( the low impedance of the
transceiver output circuit protects the input it's attached to).
