Ben
- Jan 1, 1970
- 0
Hi there,
further to my previous question I have now wound a coil to act as an
antenna for my RFID application. I don't really understand the physics
behind this, hence I don't really understand the following result, but
I'm really hoping someone can explain it to me!
Now according to the instructions of the circuit board which drives my
antenna, the antenna needs to be resonate at 125kHz, which apparently
will happen if the antenna has an inductance of 1.62mH. So, to find out
how many turns the coil needs, according to these instructions, I should
use the formula:
N=sqrt( L*(3d+9l+10e)/(0.08*d^2) )
Where N is number of coils, L is desired inductance, d is coil diameter,
l is coil width, and e is coil thickness.
I want a coil of width 10cm, diameter 1.9cm, width around 0.3cm. This
results in me needing 837 turns....
So, 1000 turns later (just to be on the safe side) I end up with a coil
which gives me a frequency of more like 75kHz when I plug it into the
board. I put in too many turns because you can easily remove turns but
you can't put them back in once you've cut the wire. But, from what I
thought I understood, more turns would equal more inductance would equal
a greater frequency? And in any case, 20% more turns wouldn't make a 50%
smaller frequency would it? So, can any tell me what I have done wrong
or which bit I don't understand?
Thanks very much,
Ben Kenward
Department of Zoology
Oxford University
use the formula:
Thanks very much,
Ben Kenward
Oxford University
