Question preservation electronic device and evaporation muriatic acid
Status
Not open for further replies.
gamer87
Mar 11, 2017
261
If at any time any muriatic acid vapor present in the air has been deposited in an electronic device, what should I do to ensure that this deposited vapor does not remain permanently on the circuit board and metals corrode?
Ylli
Jun 19, 2018
411
Protect parts that may be damaged by water (fewer than you might think), and then wash thoroughly with warm soapy water. A trip through the dish washer (set to air dry) can be quite effective.
WHONOES
May 20, 2017
1,242
Mildly alkaline solution (soapy water) should do the trick. Flush with clean filtered water afterwards then dry with a hair dryer on warm NOT hot.
gamer87
Mar 11, 2017
261
Does the pure concentration of dilute muriatic acid have any influence on the evaporation generated and does this vapor fall over the circuit boards and always remain?
WHONOES
May 20, 2017
1,242
If you have a vapour flowing over your board it is inevitable that you will get a condensate settling on the surface.
dave9
Mar 5, 2017
1,191
It's that guy who thinks everything is falling apart.
You should do nothing but evacuate the area immediately. Electronics are more robust than humans and any amount of time that you remain there is going to kill you long before it does anything to your electronics. The exception is water. Humans are more waterproof.
gamer87
Mar 11, 2017
261
I have no symptoms because of someone using muriatic in the bathroom
dave9
Mar 5, 2017
1,191
^ Then neither do your electronics have any problems from it, nor are any mitigations needed. Again, you are more susceptible than they are.
Status
