Questions board with SMD components
gamer87
Mar 11, 2017
261
electronic boards without electrolytic capacitors but with SMD components need to be used sometimes?
Having trouble keeping this card unused for many years?
Tha fios agaibh
Aug 11, 2014
2,253
If I understand you correctly, No.
The board itself should work fine regardless of how long it has been left unused. Although the memory storage may only be good for a few years.
I will say you could have trouble using this board if you continue to place it on the carpet where static electricity can wreak irrevocable damage.
gamer87
Mar 11, 2017
261
flash memory needs power usage to not erase the data? if this board go many years without being used the moisture will oxidize? at most how many days without using this plate for moisture does not create oxidation?
Tha fios agaibh
Aug 11, 2014
2,253
No external power backup is needed for flash memory cards like TF or SD cards.
I can't give an accurate answer about corrosion and oxidation because it depends on the environment. If the board is coated with a monolithic coating or varnish, that will greatly help protect it.
If its in a damp location next to the ocean, it's not going to last long before corrosion sets in.
Best advice is to just store it in a sealed static free bag and store it in a dry and preferably cool location.
The board may outlive both of us.
gamer87
Mar 11, 2017
261
What would be a cool dry place? Can you put the board inside the cardboard box closed?
