Radio Controlled Switch ?? Schematic
steve
I want to make a radio controlled switch to turn off 120 Volt lights.
I have found things like this transmitter ...
http://www.reconnsworld.com/transmit/simplerf.gif
But it has no receiver ?? Or at least I'm not sure how you are suppose
to use it.
My thought is that I would build a simple transmitter, and receiver and
add to the receiver some circuit that would pick up the signal and
eventually turn on a relay to turn on the lights. It only has to travel
about 10 feet.
Has anyone seen schematics for this, and by the way. I don't want IR
because the switch is not in line of sight.
Thanks.
Dan Hollands
to use it.
about 10 feet.
Thanks.
You can buy gadgets like this that provide an RF switch to control lamps. I
use one to have a switch inside that can control the christmas lights on the
outside of the house.
Dan
Dan Hollands
1120 S Creek Dr
Webster NY 14580
585-872-2606
[email protected]
www.QuickScoreRace.com
Sjouke Burry
to use it.
about 10 feet.
Thanks.
I used garage door transmittor switches. They use encoder bits,
so a change unwanted signal is less likely to trigger your
switch. Also it had 3 separate buttons, so you can use it
for other things.
The reciever had 3 nice relays,so you can swith whatever you
want.
Th encoding was done with 8 tristate swiches,or 512 encoding
options.
steve
Yes I have one myself. I just wanted to try to build somthing and learn
a little.
regards
steve
Unfortunetely I don't have any old garage door openers. I was trying to
find some circuit that I could build that would be relatively simple
Bob Monsen
to use it.
about 10 feet.
Thanks.
Try here:
http://cappels.org/dproj/Home.htm
He has some transmitters, but they are more of a near-field experience. It
should be fine over 10 feet, if you can get it to work.
You can also buy matched transmitter-receiver pairs here, that work fairly
well, and are very easy to interface:
http://www.futurlec.com/Radio.shtml
They are basically the same radios they put in key fobs for autos.
Regards,
Bob Monsen
"False facts are highly injurious to the progress of science, for they
often endure long; but false views, if supported by some evidence, do
little harm, for every one takes a salutary pleasure in proving their
falseness."
-- Charles Darwin
Jasen Betts
you can get auxillary receiver modules from manufacturers.
one that I've used is the one from dominator which provides 4 latching or
momentary low power relay outputs, but uses proprietary transmitters not
the gereic ones with code switches.
Bye.
Jasen
