RAM Address & data pin order
Googler
Hi ,
In any datasheet of any parallel RAM/EPROM chip, the manufacturer labels
the Address and Data pins ( D0, A0...A15 etc ).
But it is not really necessary that we connect A0 of uP/uC to A0 of memory.
( as long as we are reading from the same location where we had stored the
data, it should not matter to the uP/uC ).
Then, why is it that memory manufacturers label the Address pins as A0...etc
instead of just "Address pins" and Data pins as D0,D1..etc instead of
I/O pins or data-pins ?
does the label indicate their internal implimentation ?
or is there something more to the labeling ?
-Rgs
JW
Hi ,
Nope. It just makes it easier on us poor technicians. I can only imagine
what things would be like if everyone connected data lines and address
lines randomly. (shudder)
Mariano
I guess this could make sense in old DIP packaged EPROMS that you can
program using memory programmers. You need to use the labeling to program
the correct data in the IC. Other than this, I find it better to mix up
address and data pins according to the PCB layout. And since generally you
can program the memory using the uC/uP, there is no need of using memory
programmers any more.
Just a thought.
Mariano
Tim Wescott
Just a thought.
Mariano
It makes a difference with PROM chips that will be programmed (they
still need to be -- how does that microcontroller get it's boot code in
the first place?). You can get around that if you know _how_ the
addresses and data are mixed up, and make a program to preswizzle the
information.
It doesn't make a functional difference with asynchronous RAM.
It _does_ make a difference with flash and EEPROM, because you generally
erase those by sending "commands" -- usually by executing a sequence of
writes to addresses 0x5555 and 0xaaaa. Swizzle the address and data
spaces and this won't work, _and_ your memory blocks in your flash chips
won't be contiguous anymore.
It _does_ make a difference with synchronous dynamic RAM, where you have
lines that pretend to be data and address but are really command and
response lines, and where you want to do burst transfers.
It _does_ make a difference with synchronous SRAM, but I've never used
that so I don't know what it'll screw up beyond burst transfers.
Googler
information.
Hi
my question was WRT Async static RAM.
due to cad layout consideration, we had to interchange some Data lines.
but i wanted to know if the add/data line labeling had any deeper meaning
in case of RAMs.
it was interesting to know that interchanging lines would affect Sync-RAMs too.
Thanks.
W
William P.N. Smith
The only time it's going to matter is when some poor tech hooks up a
logic analyser and discovers "data corruption", so you might want to
document it really well on the schematics and/or silk-screen something
on the board...
