RCA Big Screen Weird IR remote issue
buzzdevil
I have a RCA Big Screen TV Model # P56927 and am having a weird Remot
control issue. Sometimes the remote just stops working. I've tried
second universal remote to eliminate it from being the problem
I have found that if you jump on the floor in front of the tv (so i
shakes a little) it will start working again. You can also make it g
out by doing the same as well. I believe that the sensor in the tv i
dirty and needs to be cleaned, but I'm not sure where it is??? Ca
anyone tell me where it is on this model so I can try and clean th
lens, or if it's loose try and repair it. Thanks in advanc
K
kip
You most probably have bad solder connections or coolant is leaking onto the
board.
It looks like a CTC195 chassis...
Best call in the TV Tech and get it estimated for repairs before you have
NOTHING.
kip
Y
Yukio YANO
buzzdevil said:
I have a RCA Big Screen TV Model # P56927 and am having a weird Remote
control issue.
Admittedly slightly off the topic but still, weird problem with Remote
Controller.
On "Motor Homes" with 12 Volt flourescent lighting, the ~ 15Kc
Inverter in the fixtures plays HELL with the IR Remote TX/RX Signal.
If one stands in front of the TV or vcr or satellite receiver and shades
the IR signal receiver from the flourescent light or just turn the room
light off, the Remote Controller will work normally. I guess the
Flourescent light blinks very close to the Remote Controllers' Signal
and drives the IR receiver "bannanas"
Yukio YANO
K
Ken G.
Cleaned ???? so when you jump on the floor the dirt falls of the sensor
then jumps back on in a few minutes ?
