RCA P # 205064 HV Tripler.
Dani
RCA keeps pushing back their availability date on this part! Does
anyone know
where to get these parts for less than $ 180.00 US??? Dani.
Tech Data
Doubt if you'll ever see an OEM again. I've had good luck with the
20.00 Chinese knockoff that's been sold for awhile. But, if you don't
want those, HR Diemen is now putting out one that techs are saying good
things about. You can check here for price and availability.
http://electronica-usa.com/
I've never used that one personally.
www.techdata-kicksass.net
Asti Magnetics. You have to use their supplied collets for the wires
and probably discard the little O rings. You also must solder the wires
to the HV feedback because they are stranded.
We are working with them to get a suitable replacement for the Zenith
A17196 as well. There are still serious problems with the connectors
but once in they do work.
Their 204809s also seem to be holding up now.
My boss has developed a repoire with Henry, and we might be guinea pigs
from time to time, but like any company, Asti wants to put out an
effective product, and so do we.
The biggest problem is someone is going to have to grind the molds for
the A17196 knockoffs. The 205064 is good enough now, as is the 204809.
Thing is there are alot of these sets out there, so it is worth
pursuing.
Now, I must say this, the flybacks for the newer HDTV Sony is not good
enough. There seems to be a problem with core saturation or something,
the HV will not regulate properly. This will be the next subject for a
powow. He (Henry) says they do not make these things, so they may well
be coming from HR Diemen, but apparently he talks to whoever is making
them, and we talk to him.
At least it is something, you can return defective parts all day long
and never get a good one if the feedback is not there. We are the
feedback now.
Wherever these parts are made we at least have a way to communicate :)
JURB
John-Del
Tech Data wrote:
But, if you don't
things about.
Everything I've ever used from Diemen has been perfect. I use their
Zenith -15 flybacks in the 1674 boards. They run cool like the OEMS
did (Chinese ones run HOT), and don't cause shutdown on high brightness
like the Chinese ones do, so they don't require fudging the feedback.
If the Diemen 205064s are easy to connect the HV wires to, I'll
definiely use them.
John
Our next step is a 1674 based Zenith, I have tried two or three cheapo
flys in it and they blow the HOT, and I mean they blow a 2SC5150. If
they run long enough I can see they ring at about 8 uS. There were a
few that rang at about 11 uS and I padded them. My fingers are still
crossed.
IMO, if they ring less than 10 uS they will not be reliable.Not that
anything is anyway.
BTW, I dunno if you saw, I got a fix for the piecrusting when using a
cheapo 239111, you put a 10K resistor to ground from pin 25 of the
LA7610. Similar procedure for the 7612 but I don't have it in front of
me. Had to do this to save some nice 32" sets.
Pretty much a shame, once just about get the 17196s and the -15s
straightened out the tubes will probably start going bad en masse. we
are just getting into this with the CTC169s, although I have seen bad
tubes in a CTC195 too. PTK that is.
Thing is we live in a time where we are going to see very little
support from the OEMs, and the sheeeple will keep buying new. We will
eventually lose, and that is why I work for someone else, an older guy.
When he retires I do not come with the place. I will do something else.
For now we need the words "Your set is fixed".
JURB
