reading capacitor value from code printed on it?
  • Thread starter Bill Christens-Barry
  • Start date
I have a circuit board with a capacitor that needs replacing (it got
burned when an adjacent triac went out). The capacitor is a small "bead"
shape, and has the code:
1C4
ME5
printed on it.
I can't find anything on the web about this particular code format - can
anyone help me figure out what its value and max voltage is?
The circuit has another one of these capacitors, and I thought about
pulling it and trying to test its value. My idea is to charge it up to a
known voltage, and time how long it takes to discharge through a known
resistor. My problem is that I don't know what the impedance of the DVM
voltmeter is, and this will influence the discharge rate due to its
parallel resistance. Any ideas on how to approach this? I guess I could
do this experiment twice, using two different known resistor, and back
out the meter resistance. Any better ideas? I don't have easy access to
any good electronics bench equipment, so am looking for simple approach.
BTW, I could post a digital closeup photo of the capacitor if that would
help.
Thanks.
Peter Bennett
1C4
ME5
printed on it.
Any chance that it is actually 104 rather than 1C4 - if so, it may be
an 0.1 uF capacitor - very common value for power supply bypass
capacitors.
Peter Bennett, VE7CEI
peterbb4 (at) interchange.ubc.ca
new newsgroup users info : http://vancouver-webpages.com/nnq
GPS and NMEA info: http://vancouver-webpages.com/peter
Vancouver Power Squadron: http://vancouver.powersquadron.ca
Geir Klemetsen
1C4
ME5
printed on it.
help.
Thanks.
Best sugestion:
Go buy a capacitance meter.
Second best suggestion:
Build an oscillator that make use of _one_ capacitor. It's important that
you are able to calculate the oscillation frequens for that particular
oscillator. You have an formula f = (r, c). Turn this into
c = (f, r).
Example: http://www.national.com/an/AN/AN-31.pdf page 8. The formula should
be like this:
T = 2 * R1 * C1 * ln( 1 + ( 2*R2/R3 ) ) ( T = 1/f )
Turning the formula to calculate C:
C1 = T / ( 2 * R1 * ln( 1 + ( 2*R2/R3 ) ) )
Hope this helps : )
Geir
capacitors.
Yes, that turned out to be the answer! Careful inspection
showed that some of the paint had chipped off.
Thanks.
Geir Klemetsen
1C4
ME5
printed on it.
help.
Thanks.
Wm A Christens-Barry, PhD
Equipoise Imaging, LLC
[email protected]
http://www.eqpi.net/eqpi/
Best sugestion:
c = (f, r).
be like this:
Hope this helps : )
Geir
Btw: This is second time i post this message. It doesn't show up in the
news-group after the first time I posted it.
