Jeff
- Jan 1, 1970
- 0
Sold by the pound these were..........
Got one - output on one side was heating up & diving into the
protecion pool,
removed both amp cct's - measured every transistor from arse to
breakfast - both channels identical.
Re-installed them, no more heat but the weaker channel plays with
intermittent staticy ocean-like noise. Two trim-pots on each channel -
contact cleaned - adjusted for volume - helps some - still
intermittent static.
Good channel - toshiba outputs
Bad channel - sanyo outputs not sure which channel was changed - I
believe the latter.
Leaky tranistors?
What are the pots?
Service Manual available anywhere?
Tapping the cct boards does not fault the problem so I've ruled out
solder joint trubbles.
Thanks.
protecion pool,
believe the latter.
Leaky tranistors?
What are the pots?
Thanks.
