Really OLD logic levels
Today we use LVD (low voltage differential) logic, at low voltage levels; before
that, there was HVD (RS-485), ECL, TTL, DTL, and a few odd items
like the high-voltage DTL of MC1488, and CML (current-mode
logic?) and such.
Don't forget the high threshold logic families (15 V) used in
industrial applications.
But 'WAY back there was a system with high power supply voltages
(about 450V) and very peculiar antenna-based sensing
Why would anyone use such high voltages for digital logic ? This
would require quite high impedance levels and due to the stray
capacitances, quite slow operation.
For instance the 5965 double triode was operated at about 100-150 V
anode voltage supply. The early semiconductor diodes used to build
diode/tube logic NAND/NOR would not have tolerated much more.
As strange as it might sound, the early semiconductor diodes were more
unreliable than tubes.
Tim Williams
I've never heard anything about vacuum state logic levels, if any
companies even defined their own logic standards -- I would guess
something in the neighborhood of, say, -20/0V (requires low current C-
supply) or 50/100V (requires cathode bias = wastes power).
Tubes aren't so bad. I've done, I think it was -80/0V drive into a sweep
tube, which is equivalent of driving a 6000V, 1A MOSFET to produce
sub-150ns edges (comparable to... lazily driving an IRF540, I'd say).
Such high voltage MOSFETs don't even exist [yet], so I guess toobs win
that battle. :p
Umm, read the link..
Tim
gregz
logic?) and such.
<http://phenomena.nationalgeographic...ees-can-move-each-other-with-electric-fields/>
I worked with stuff negative voltage, even saw negative logic
Collins logic, dec logic, zerox logic, general dynamics dynamic logic.
Greg
W
whit3rd
On Thu, 4 Apr 2013 14:27:35 -0700 (PDT), whit3rd <[email protected]>
It was because the power supplies (highly redundant, a system would operate
with a few hundred of 'em) weren't regulated, except by corona leakage to atmosphere.
Higher tech for regulators (gas discharge tubes, Zener diodes, bandgap references)
was unavailable. :)
