Rechargable batteries
  • Thread starter Wilfred Xavier Pickles
  • Start date
Charlie
Ian Field said:
As I only gave the page a cursory glance I may have missed where it said
"NiMh" - OTOH they look like the rechargeable alkalines which can only be
recharged a *very limited* number of times and only then if you never
discharge them flat, and only with a special charger.
Make sure you buy NiMh cells, it doesn't matter if the Ah capacity is
higher than the originals (technology keeps improving) anyway, most makers
claim NiMh are immune to memory effect. They'll just take longer to reach
full charge and last longer before next charge.
As long as the old cells haven't failed S/C, put them in a fast NiMh
charger and then run them down in a (filament bulb) flashlight - repeat
charge/discharge cycle a few times, you may see some improvement.
Zoom in to the Amazon image and you will see NIMH in the lower left corner.
W
Make sure you buy NiMh cells, it doesn't matter if the Ah capacity is higher
than the originals ...
Part of the reason I had to ask was because I couldn't *find* a mAh
rating on the Amazon page.
Anybody see one?
Will
Phil Allison
"Arfa Daily"
It says that they are NiMH at the the bottom left of the card, and it
indicates on the battery body that they are 2400mAH,
** Nope.
DX2400 is a code that gives the battery type and size.
Seems they are really Sanyo Eneloop AAA cells in a new skin.
So they are 800 mAH.
AAAs are never 2400mAH.
.... Phil
Jeff Layman
"Arfa Daily"
** Nope.
The main Amazon page shows AAA batteries. When the image is zoomed it
shows AA batteries!
The back view of the pack cannot be zoomed, but magnifying the image
shows they are 2800 or 2900 mAh.(top right).
W
And if I'd like to be -certain- of the mAH rating, maybe I
should just buy the Sanyo Eneloop for not-much-more money?
Will
