relay switching speed
lerameur
hello,
I am trying to figure out is there is any rating on the maximum
switching speed on mechanical relays such as the R3-24AC or 50-094-0
(or just any mechanical relay) I want to use dc current on these and
switch them possibly 1000Hertz or possibly 10,000Hertz. what is the
maximum speed they can be continuously switch?
thanks
K
Sjouke Burry
lerameur said:
hello,
thanks
K
The "on" switching time is depending on the speed with which
you can push current into the relay coil, and would rather
quickly get into the range to burn out the coil, if you want
high switching speed.
The "off" switching time however depends two things, first how
fast you can kill the current in the relay(rather difficult),
and secondly on a metal spring in the relay to pull the relay "open".
The spring is what is limiting the ultimate speed.
An ordinary relay will be ~50-200 hz, and very small relays, like a
reed relay for example might be pushed a bit higher, like 200-400 hz
A quick test would be to put the NO contact in series with the coil,
and make it self-switching, acting like a buzzer.
You can increase the supply voltage a bit, but you risk burnout of the
coil.
Also the contacts wont last long.
1000Hz? unlikely.
10000hz? wishful thinking.
If you really want fast mechanical switching , use a rotary switch,
driven by a motor.
Using FET switches, you can get into the Megahz range.
lerameur
coil.
1000Hz? unlikely.
driven by a motor.
Ok I found this part at Digikey.com
CLA280-ND
it is a static relay, that can handle the required switching but it
is not a SPDT, and there are no SPDT in the 6 amps or higher
regions.... are these high power relays done in static technology?
K
W
whit3rd
switching speed on mechanical relays ...
Firstly, if the coil current is modulated at 1000 Hz, this is NOT DC
current
we're talking about. On every cycle, you'll generate some core heat
due to magnetization losses. This may be important. Smoke
is possible. Do not expect that 'normal' operating voltages are
sufficient, either
Secondly, the 'ON' position of the relay is achieved by hitting a pair
of parts together , and they either progress to hammer each other
out of shape OR they engage in elastic deformation. That elasticity
means there is bounce, and the 'ON' status is very much compromised
until the bouncing stops. This is the one, the only, item that a
relay
manufacturer is likely to specify about the short-time character of
the relay.
And third, the 'OFF' position usually is a long way from the 'ON',
so that sparks don't occur. If you expect 5 kV operation, or 50 mV
operation, the suitable delay-to-OFF time will be quite different.
Some small-signal (telephone) relays have impressive contact lifetime
with circa 50V stress; lower voltages have dirt-related reliability
issues, and higher voltages have wrath-of-Zeus related reliability
issues.
At 1 kHz your prospective device will hit millions of times per hour,
and contact life will be a major issue. Practical vibrators (I seem
to recall)
worked at tens of Hz.
The literature on this kind of application is heavily influenced by
Motorola
and relates to early car radios (which Motorola made); the oscillating
'relay' was called a vibrator, and failed as frequently as any of the
vacuum
tubes.
Jamie
lerameur said:
hello,
thanks
K
Most likely induction is to high in the coil for that kind of speed,
you'll never get enough current to pull the contacts.
Assuming this is a 24 Volt AC coil, it has been wound and designed
to create enough current with in the cycle time of 50/60 hz..
Ect...
http://webpages.charter.net/jamie_5"
Jasen Betts
hello,
thanks
typical DC relays are good to something around 100Hz
(AC relays have slower switching rates)
you may be able to coax higher rates by closed loop control
ISTR getting about 300Hz in this way once. (i wired the NC contats in
series with the coil and adjusted the supply for the highest pitch)
if you want to go higher you may need to consider piezo actuators
instead of magnetic, or go solid-state instead.
Bye.
Jasen
kammenos
Aug 18, 2008
lerameur said:
hello,
thanks
K
Absolutely imposible. Relays are not to work like this. They are to carry heavy loads. You should consider using some kind of transistor or anything else. What exactly are you trying to make?
Bob Eld
lerameur said:
hello,
thanks
K
Forget about it. As mentioned in all of the above posts, relays are far too
slow for your application. AC relays are even slower because they have a
copper "shade" on the pole piece to deliberately keep the field from
collapsing fast. This keeps the relay from chattering on AC drive.
Your application requires electronic switching for the speeds you mention.
Transistors, FETs, SCRs, etc. should be considered depending on the exact
requirements.
Ross Herbert
:Ok I found this part at Digikey.com
:CLA280-ND
: it is a static relay, that can handle the required switching but it
:is not a SPDT, and there are no SPDT in the 6 amps or higher
:regions.... are these high power relays done in static technology?
:K
Did you look at the datasheet?
http://clareweb2.clare.com/home/pdfs.nsf/0/614B59328CA886C28525726600495950/$file/CPC1709.pdf
Max T-on is 20mS and max T-off is 5mS. This limits the maximum (reliable)
operating speed to 40 operations per second but you would need some safety
margin. Say around 37 ops per second guaranteed.
A reed relay will typically have operate and release time of around 1mS but they
can't handle the current you are talking about.
neon
Oct 21, 2006
1,325
lerameur said:
hello,
thanks
K
just forget relay for that speed theywere never meant to switch that fast. reeds might do it as mechanical switching but even them are not realibly at that speed . BOTTOM LINE FET or transistors.
