Repairing 21" monitor - worth it or not?
Apropos
I have a Gateway 21" monitor about 10 years old.
It quit working. Were it a smaller monitor I would just toss it but being a
nice 21" I would like to get SOME idea what it might cost to have this
fixed.
The problem is that there is no image at all. Everything else seems to work
fine however. I hear the normal "hum......click" when the monitor is turned
on but no image appears. I hear the normal "voom....click" when I press the
de-gauss button. Connecting my laptop to it, it "sees" the monitor
connected. However, despite whatever I've tried (including different
cables) no image appears.
I'm just trying to get a ROUGH idea what it might cost to fix this, to see
if it's worth even seriously considering fixing.
Charles Schuler
a
fixed.
work
turned
the
Could be a high-voltage problem or a horizontal output problem. If you are
lucky, one new transistor will fix it.
As to the worth of fixing it, it depends on what kinds of service shops are
available to you. The repair cost would be around $90 - $130 if it is
something simple like a horizontal output transistor. After 10 years, it is
likely to quit on you again.
My prediction: You will most likely replace it.
Matt J. McCullar
If you can remove the back cover, see if there is an orange glow inside the
neck of the picture tube. You may need to turn out the room lights to see
this. If you can see it, then the problem may be as simple as bad solder
joints on the socket on the circuit board that plugs into the back of the
tube. This board usually has a metal shield soldered to it, making looking
for bad solder joints a bit tougher. But this is a common problem.
b
fixed.
often if a power supply detects an short or other problem on one of the
outputs then it will shut down. This may be why the relay clicks. there
could be a shorted vertical or horizontal problem.
In a monitor this old,and judging by the symptoms you mention, the
line output transformer may well be bad (recently I have seen several
monitors of this vintage with bad LOPTXs) but before fearing the worst,
try testing what the other posters have mentioned, resoldering etc.
Also check the HOT for shorts, and with it removed connect a 100w
bulb across c-e and plug in, see if you have B+.
replacing the other parts, such as transistors etc. will not cost more
than pence really if you do it yourself. Only the LOPTX is dearer,
typical prices round here are between 20-60€ for a new one. I
wouldn't bother with this if I was workign on a 10 yr old monitor
personally.
-Ben
judges123
fixed.
Can You give the date of mfg. model Number and ,,,fcc number??
Might have it in a database.
Joe Smith
Westpoint Monitor Repair
Joel Kolstad
Nice used 21" monitors on eBay go for about the same price. On the other
hand, brand spankin' new 1600x1200 20" LCDs are only $300 these days -- I'd go
that route.
fixed.
the only way to know the price is to get a free quote. Too many
variables to predict. I'd avoid the freshly painted looking repair
shops as they'll charge twice the price. This is one of the very few
industries where going to the backstreets is better.
NT
James Sweet
that route.
You'd have to find one local though, shipping alone would be close to
$100 these days for a well packed 21" CRT.
