replacing bulb in a Panasonic Microwave Oven Model NN-T990SA
muckraker
I have a Panasonic Microwave Oven, Model NN-T990SA. The appliance
bulb that illuminates its interior has burned out, and I would like to
replace it. I see two possible access routes. Can you steer me to
the right one? First, there's a fiberboard square on the right,
inside wall that appears to pivot on a nylon pin; it looks like I
could free two corners of the fiberboard by gentle prying and flexing.
Is that how it works? Or, should the nylon pin be pried out? Does
the opening behind the fiberboard give a sufficiently large pathway to
reach the bulb? Second, on the underside of the unit, beneath the
front control panel, there is a single screw. I assume that removing
it would enable me to pull the control panel forward. Would the bulb
and its socket be attached to the backside of the control panel?
If replacing the bulb would require special tools, I wouldn't attempt
it.
Appreciative of any suggestions!
James Sweet
it.
In every microwave I've seen you access the bulb by removing the whole top
cover of the unit, there's usually some screws around the perimeter of the
back panel or the sides.
I suggest reading the repair faq before doing this though, common sense will
keep you safe, but it's not too hard to get yourself killed if you poke
around the wrong areas without taking precautions.
Art
Agreed: The original operations manual will tell you what needs to be done
to replace that bulb. However, if in doubt, it may be better to have it
professionally done. These items can and have been "widow makers".
F
Franc Zabkar
The lamp in my microwave oven is user serviceable. It is accessible
via a cutout in the top cover.
- Franc Zabkar
Scottie Mack
On this particular model, the bulb MUSTt be removed by taking off th
top cover as the bulb and holder is one assembly. It is held into lam
housing by two nylon clips. (don't flex these back too far whe
removing as they will break off)
The bulb/holder is a Panasonic part and should be available throug
http://www.partstore.com/
And as with all electronic devices UNPLUG it first
