Guest
- Jan 1, 1970
- 0
(previously posted in sci.engr.biomed)
Seems that it could be done with a handful of off-the-shelf parts. From browsing the group, I've seen where these are often
class projects.
Purpose - Determine specific muscle maximum output.
Input- Standard skin electrodes.
Output - LEDs preferred over sound.
Requirement - no programmable chips.
Application - I severed the median and ulnar nerves (and a bunch of other stuff) just above the elbow. After a couple surgeries,
I've gained some motion in my thumb, and I'm trying to exerecise it to the max muscle activity level.
I've used a commercial unit in the Occupational Therapy clinic, but it has a fancy LCD display with mmv readings, timers, etc.
that I don't need.
I visualize an output of a simple string of LEDs. If I remember correctly, the commercial unit displayed readings of 10 to 60
mmv, depending on pad placement and fatigue level. With luck, this will increase, but I don't know what normal limits are, and
don't expect to get anywhere near normal levels. Changing ranges would be a nifty.
Seems it could be done with a power supply, amplifier, and LED driver chip, or maybe easier.
Any suggestions?
Ken,
Thanks for the links; I'll check them out. I googled for 2 days, obviously with the wrong key words, and all I could find were
block diagrams and theory.
As far as skills, that's changed a tad, which leads to my request. I've breadboarded a lot, and made enough basic one-sided
circuit boards to be comfortable with the process.
Now, I call whatever I do 'therapy', and often recruit family to hold things for a second.
Yes, desire is 'cheaply' - crude, if need be. A simple gazinta / comesouta. On the lines of a science fair project would be
adequate.
Thanks, again.
Path:
beE1!out03b.usenetserver.com!news.usenetserver.com!in04.usenetserver.com!news.usenetserver.com!nx01.iad01.newshostin
g.com!newshosting.com!216.196.98.140.MISMATCH!border1.nntp.dca.giganews.com!nntp.giganews.com!local01.nntp.dca.
giganews.com!nntp.comcast.com!news.comcast.com.POSTED!not-for-mail
NNTP-Posting-Date: Thu, 01 Feb 2007 20:33:09 -0600
Newsgroups: sci.engr.biomed
Subject: Re: Req: Schematic for BASIC electromyogram (EMG) - biofeedback type device
References: <kxqwh.17361$%[email protected]>
Message-ID: <[email protected]>
User-Agent: Xnews/5.04.25
Lines: 79
NNTP-Posting-Host: 75.72.187.89
X-Trace:
sv3-swZKurxPXYUqHG9e6bu+vSXGtG1Ip1EQyMyzHu94Pus8G8XizYZk1UbZP7M1+KS3AeezBN6Y+CXoHSO!V5Z/
9G5nJpKz9upaovdWs30sOdHny/cICQyZ3rWG+QZqECPsFdGc2LYzWxkmiWAIVcPd3lrTFmBc!+Gjb
X-Complaints-To: [email protected]
X-DMCA-Complaints-To: [email protected]
X-Abuse-and-DMCA-Info: Please be sure to forward a copy of ALL headers
X-Abuse-and-DMCA-Info: Otherwise we will be unable to process your complaint properly
X-Postfilter: 1.3.32
Xref: usenetserver.com sci.engr.biomed:114104
X-Received-Date: Thu, 01 Feb 2007 21:33:10 EST (beE1)
Joe,
The input circuitry for EMG is very similar to that used for
EEG and ECG. Basicly a high CMMR, differental amplifier with
a lot of gain. The difference is in the filtering, and what
you do with the output. Though in EEG and ECG they are trying
to filter out the muscle (noise) signal, that you want to
use.
I used to work in Biomedical Engineeing at the U of Minnesota
Hospitals, but would have to dig to come up with a design
from a "handfull of off-the-shelf parts"...for what I assume
you want to do cheaply(?). What are your skills electronics?
Try posting your request over on the newsgroup:
sci.electronics.design
and
Google: EMG circuit schematic
I got lots of good hits, including:
http://mxp.physics.umn.edu/s02/Projects/Muscle/Project_Propos
al.htm
GO GOPHERS!
This should do what you need for the front-end. Instead of
sending the signal to a computer you could try driving an LED
bar display:
http://www.national.com/pf/LM/LM3914.html
You may need to put some signal conditioning circuitry
between the input and the display, but I'll leave it there
for others to help.
As my flight instructor used to say: "Do good work...and have
fun"
Ken Moffett
Scientific Instrumentation
Macalester College
class projects.
that I don't need.
Any suggestions?
Ken,
adequate.
Thanks, again.
Path:
Lines: 79
X-Trace:
Joe,
use.
and
al.htm
GO GOPHERS!
bar display:
for others to help.
fun"
Ken Moffett
Macalester College
