resistor color code help
Gary Woodruff
Howdy all I have a resistor on a front panel tv control that has a 5
band color code of brn-blu-red-gold-grn. This resistor is not burnt but
measures 1.62K ohms. from the color code I would suspect 16.2 ohms. If I
replace the 1.62k with a 16.2 the set will not power on. If I put the
1.62k back in set powers and then shuts down after 5 seconds. There are
many posts that identify the front panel cb as the culprit.(circuit
board is no longer available from RCA). There are 4 or 5 resistors and 6
tact switches, and one cap on this board. this resistor is the only
component in the circuit with the on/off tact switch. My main confusion
is the color code and value of this resistor, am I missing something???
Gary
I
ian field
Gary Woodruff said:
Howdy all I have a resistor on a front panel tv control that has a 5 band
many posts that identify the front panel cb as the culprit.(circuit board
is no longer available from RCA). There are 4 or 5 resistors and 6 tact
switches, and one cap on this board. this resistor is the only component
in the circuit with the on/off tact switch. My main confusion is the color
Gary
It has 3 significant digits instead of 2 and the final value band is the
number of 0's.
A good example of scaling is: a brown/black/orange is 10k -
brown/black/black/orange is 100k.
Faulty resistors in low power circuits are rare - are there any
electrolytics on that board?
Gary Woodruff
Ian , thanks. The band in question is the 4th gold band the multiplier.
Gold will give me a value of 16.2 ohms, however the resistor measures
1.62K ohms. I would expect the multiplier to be brn to get the 1.62k
that the resistor actually measures??
I
ian field
1.62K ohms. I would expect the multiplier to be brn to get the 1.62k that
You will get flamed if you keep on top posting.
Jamie
Peter said:
I'd say the value is 1.6K, 5%. The final green band may be a
temperature code.
WOw, you are the first the get it correct.
Gary Woodruff
Thanks to Peter Bennett. I concur it is a 4 band resistor with a fifth
temp band. The resister is in a low power circuit and has no sign of
damage or overheating.
