Nick Marino
- Jan 31, 2015
- 6
- Joined
- Jan 31, 2015
- Messages
- 6
Can anyone tell me what the value of this resistor is?
https://skydrive.live.com/redir?resid=9F9074D3C9AAB530!2664
Also by looking a the bending of the leads this resistor is NOT sized correctly. The wattage is way over-utilized. If and when determined its original value try a 10W+ in it's place, then scale down.That resistor has obviously been running very hot for a long time. I wouldn't trust any of the colour bands to be their original colours, except perhaps the green one. Measure it, but unless it's within say ±10% of a value starting with 5, its measurement may be wrong as well.
If you post some photos of the board that it came out of, we may be able to estimate an appropriate value.
I think this confirms by original post of green brown gold = 5.1Ω It measures close enough to be a 10% tolerance resistor of that value.I did try and measure it, I had my meter set on two hundred omhs and it read 5.56 out of the circuit. when I set it any higher than 200 I got no reading at all.
yes R4, also I was wrong about the reading I was getting,
when I set my meter to 2k it reads 5.65 and when I put it on 200 I get no reading.
..... and when I put it on 200 I get no reading.
That doesn't quite make sense.when I set my meter to 2k it reads 5.65 and when I put it on 200 I get no reading.
