RS232 addressing
pmciprian
Sep 3, 2011
I would like to know if anyone could get me started on a project for designing a circuit that will check the first byte sent over RS232 and if it matches a set of dip switches, it will passthrough the rest of the RS232 signal to another controller, otherwise it will passthrough nothing. Any advice would be greatly appreciated.
Phil
sid2286
Aug 24, 2011
102
Are your dip switches connected to certain port?
1.read the port status first.
2. Check the incomming byte from RS-232
using if condition or a while
eg
if(port_status==Incomming_byte)
pass to other controller;
else
do nothing;
OLIVE2222
Oct 2, 2011
690
As RS232 is not intended to be chained you need to work on hardware side too.
here under a link to such an application:
http://www.weedtech.com/an100.pdf
having a µC with 2 UARTS (like the ATMEGA644P) will also be a solution
cheers,
Olivier
