rs232 interupt on old ibm pc type machines
H
Hul Tytus
sci.electronics.design
Below are an rs232 initialization and a handler routine that work well on
later vintage ibm pc types, roughly 200 mc and above. The AT vintage types
however are a bust. The 8250 registers and the interupt mask register in the
interupt controller appear as expected in both cases.
Anyone have an idea what is missing for the older machines?
Hul
_____________________________________________________
; interupt enable bits
DATAIN equ 1 ; data availalbe
TRANEMP equ 2 ; transmit holding reg empty
RECLINE equ 4 ; receive line status
MODSTAT equ 8 ; modem status
ptype rsinit ; rsinit(port) -- port assumed 0 for now
; initialize interupt req #4 (int 0c) for rs232 line
push bx
push cx
push dx
push ds
mov ax, DDDTA ; base of data
mov ds, ax
mov dx, 0
call irsadd ; return port address for '0' port (com1)
inc dx
in al, dx
or al, DATAIN ; enable incoming data interupt
out dx, al
add dx, 3
in al, dx
or al, 8 ; set out2 bit in uart to enable interupts
out dx, al
push cs
pop cx
mov dx, offset rs4hand ; new address for irq 4 handler
; see below
push ds
mov bx, 0
mov ds, bx
mov bx, 2ch
cli
mov ax, [bx] ; read old address and
mov [bx], dx ; place the new one
add bx, 2
mov dx, [bx] ; ditto
mov [bx], cx
sti
pop ds
mov word ptr ds:[intcadd], ax
mov word ptr ds:[intcadd+2], dx ; the org address has been saved
mov dx, 21h ; interrupt control reg
in al, dx ; read current interrupt mask register
and al, 0FFh-10h ; allow interrupts from COM1
out dx, al
pop ds
pop dx
pop cx
pop bx
ret
rsinit endp
rs4hand proc near ; handler for interrupt #4
sti ;Allow interrupts ?
push ax
push bx
push dx
push ds
mov ax, DGROUP
mov ds, ax
mov dx, 20h ; System interrupt controller
mov al, 20h ; Reset interrupt pending
out dx, al ; Put back to system controller
mov dx, 0 ; assume port 0 -- ie COM1
call irsadd ; returns address for passed port
inc dx
inc dx ; point at interrupt id reg
in al, dx ; get interrupt type
test al, 1 ; any interrupt pending?
jnz rs4hnd1 ; no - return
cmp al, 4
jnz rs4hnd1
dec dx
dec dx
in al, dx
call rsinplc ; places al in recieved data buffer
rs4hnd1:
pop ds
pop dx
pop bx
pop ax
iret
rs4hand Endp
Jasen Betts
http://en.wikibooks.org/wiki/Serial_Programming/DOS_Programming
any help?
Tim Williams
Don't see anything wrong offhand, but I don't remember the serial port so
well.
I have an XT-compatible if you'd like to test further back.
The BIOS, and DOS, have some serial drivers, but I don't remember if
interrupts are offered. It's pretty standard to work directly with the
serial hardware, so that doesn't matter much.
You should ask DOS to patch in the interrupt -- see INT 21h, AH = 25h.
That way if your program closes abruptly, DOS knows what to fix.
You can also further use DOS to install your own CTRL+BREAK handler (INT
23h) if occasional freezes are a possibility, as sometimes happens in
development.
BTW, which assembler are you using? I mostly use MASM, have you
considered it? Automatic stack frames is niiice. ;-)
Tim
Deep Friar: a very philosophical monk.
Website: http://seventransistorlabs.com
on
types
the
Hul
push bx
push cx
push dx
push ds
mov ds, ax
mov dx, 0
inc dx
in al, dx
out dx, al
add dx, 3
in al, dx
out dx, al
push cs
pop cx
; see below
push ds
mov bx, 0
mov ds, bx
mov bx, 2ch
cli
add bx, 2
mov [bx], cx
sti
pop ds
out dx, al
pop ds
pop dx
pop cx
pop bx
ret
rsinit endp
push ax
push bx
push dx
push ds
mov ax, DGROUP
mov ds, ax
inc dx
cmp al, 4
jnz rs4hnd1
dec dx
dec dx
in al, dx
rs4hnd1:
pop ds
pop dx
pop bx
pop ax
iret
rs4hand Endp
