Run a 9.6 volt Makita drill off 12 volt car battery - voltatage dropping resistor ?
I want to run an old Makita 9.6 volt drill off my car battery 12 volt (
actually 13.6 volt ) . What is the approriate resistor to use ?
-thanks
Jim Yanik
[email protected] wrote in
-thanks
Well,the Mak 9.6V stick is at 10.8V at full charge,IIRC.
With the high currents to be drawn,I'd use a regulator IC instead of a
dropping resistor.
Sam Goldwasser
Simplest is a few high current diodes in series to drop the voltage.
You can't use a resistor because the current is not known and not
constant.
--- sam | Sci.Electronics.Repair FAQ Mirror: http://repairfaq.ece.drexel.edu/
Repair | Main Table of Contents: http://repairfaq.ece.drexel.edu/REPAIR/
+Lasers | Sam's Laser FAQ: http://repairfaq.ece.drexel.edu/sam/lasersam.htm
| Mirror Sites: http://repairfaq.ece.drexel.edu/REPAIR/F_mirror.html
Note: These links are hopefully temporary until we can sort out the excessive
traffic on Repairfaq.org.
Important: Anything sent to the email address in the message header above is
ignored unless my full name is included in the subject line. Or, you can
contact me via the Feedback Form in the FAQs.
N
NSM
| -thanks
Do you want to charge the 9.6 V batteries from the car?
N
Well......unless you're automotive battery is hooked to a typical charging
system, your auto battery at rest will be more like 12.3 to 12.6
volts........current will only be in the range of a few amperes but will be
quite variable as pointed out. I'd try a string of 4 silicon diodes inline
with your made up cord for a typical voltage drop of 2 volts which will be
somewhat constant despite the current drawn. These could be nearly
anything with a rating of say 10 amps @ 50prv min and wouldn't have to be
even the same........use what ya have. This solution will have the added
benefit of giving you reverse polarity protection should your cable to the
auto battery get reversed. If you bring your cord into the bottom of the
old battery compartment there'd be enough room to include the string right
in there as it's quite long....strain relief below that. Realize that
your auto battery voltage will sink as you use it (uncharged....portable so
you can lug it close to where you want) and this won't hurt things at all.
Let me know how ya make out (have a couple of these drills myself). I can
picture powering it off of one of those booster battery packs as a good
solution for portability..........use a cigarette lighter plug so you can
power right off this or your vehicle or via a battery clip adapter for open
other types of batterys.
Gord
mike
I'd recommend against using the cigarette lighter plug. They use some
mighty flimsy wiring in auto dashboards these days. And newer cars
switch the lighter socket with a relay of unknown current capability.
Worry about the drop in the wire. It's gonna be long if you expect to
use the drill outside the vehicle. And for flexibility, you'll want the
smallest wire you can get away with. Sounds like some actual
measurements on the system in question are in order.
mike
Return address is VALID.
Wanted, Slot 1 Motherboard
500MHz Tek DSOscilloscope TDS540 Make Offer
http://nm7u.tripod.com/homepage/te.html
Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
Bunch of stuff For Sale and Wanted at the link below.
http://www.geocities.com/SiliconValley/Monitor/4710/
rpbc
I use a couple of those drills, including a 7.2 volt Makita, all the time
directly off the vehicle battery. They are very tough, you just get more
torque and rpm. I was actually just curious at first, figuring I'd just
throw the drill away if it burned up. I use them all the time though and
they continue to work fine. If you want to drop the voltage the diodes in
line are the cheapest and best way to go. Resistors are no good for when
current increases due to motor load demand, voltage distrubition to the
motor will be decreased and there will be an overall loss of power
available at the motor. My advise is to just hook it up to the 12 volts
and don't worry about it.
rpbc,
That's good to know. I've had a 7.2 V Makita hand vac that I use with
the 9.6 V batteries all the time since I've got 2 9.6 V drills, 2
flashlights and a recip saw. That little vac screams at 9.6 V and works
very well. It has thrown a turbine disc in the 7 years I've been
running it that way but that was easily repaired with a part from Tool
Barn. The salesman that sold it too me showed me that trick.
Richard
Thanks Gord - This sounds like it might be the a good solution . I
now need to look around for some of the diodes you mentioned ,
James Sweet
You can get them anywhere, even Radio Shack. Personally I would just run the
drill straight off 12v though, these little motors have very wide voltage
rating ranges, the 12v drills probably use the same motor, just a bigger
more expensive battery pack.
