SAE 2200 amplifier transistor sub?
F
frontline@nospam
Toshiba S1375 and S1376 used in this 1979 SAE 2200 amp do not seem to
be around anymore, anyone know some good subs for them?
Thanks, Jeff
F
frontline@nospam
General subs and not available in matched pairs, thanks but thats not
the type of "sub" I am looking for, as of now all the info I have on
these parts is NPN/PNP and voltage and the gain group marks on the
parts but without datasheets I can not cross them to "good subs".
One other note on this amp, 50% of the caps on the driver board were
bad in both channels one was blown one was still working.
Maybe I should ask if anyone has datasheets on these S1375 and S1376
Toshiba transistors?
Thanks Kip,
Jeff
K
kip
Why not at least try the NTE,s they are cheap enough ,then go looking.
kip
F
frontline@nospam
I have used ECG and others in the past and most of the time they work
but when they do not you can waste a lot of time finding out why.
Mostly this is an audio amp using matched NPN and PNP circuits the
closer I follow that the longer the amp will last and with smaller DC
offset, this amp only has bias adj. and I am only repairing one channel
at present so also going for as close to that as possiable and I do not
stock many general replacement types and do stock many japanise,
american and european transistors in matched pairs for this reason.
Actually I would have ordered the NTE if they had matched pairs "MCP"
after the number.
Jeff
tlw
Jeff,
I still have a copy of a service bulletin I received from SAE years ago
concerning these transistors. The S1375 subs to 2SC1913 and the S1376 to
2SA913. NOTE-the lead configuration is different!!! Hope this helps.
tlw
